Bottles works
Bottles works - Tried many approaches to run the SMathStudio finally found a simple solution - Сообщения
#1 Опубликовано: 28.05.2026 16:29:45
Tom S
Tom S
It as been a long road to find something that actually worked. I installed Zorin OS 18.1. Downloaded the SMathStudio ... .appImage, if failed to launch
The forum suggest down loading SMathStudio ... .tar,gz and expand it to create a momo folder. A procedure suggested to use was years old and the programs told to use were way out of date and not even available.
I have a windows pc also which had no problem installing SMathStudio ... .msi
The wine that match Zorin OS 18. Failed when running SMathStudio ... .msi giving a problem with NET version.
What does work is Bottles that match Zorin OS 18. Ran SMathStudio ... .msi with the starting page on the screen.
#2 Опубликовано: 28.05.2026 16:42:41
Actually problem is Mono installation of all debain (or ubuntu) based distros.
It is broken for nearly two decades, and there is no fix of I know.
Only proper way to correct this is manual reinstallation of Mono.
Try to do what I had done in this reply, pretty sure SMath will run.
In fact, this will fix Mono for all c# programs using it.
https://smath.com/en-US/forum/topic/QGuTDE/Cannot-run-in-Ubuntu-22_04#msg143067
