Path in window title bar
Path in window title bar - Сообщения
#1 Опубликовано: 17.08.2018 12:14:57
dio pants
dio pants
16 сообщений из 180 понравились пользователям.
Is it possible to add the file path in addition to the filename in the window title bar?
Or maybe make it a preferences checkbox option.
Often times when using a repetitive calculation, I find that I am working on the one in the wrong folder.
#2 Опубликовано: 17.08.2018 14:54:15
Hard to understand why working the same document in different folders.
To minimize crashing save the same document in the same folder
Save as copy ... alternate between the copy and the not copy .
#3 Опубликовано: 19.08.2018 20:13:21
1 132 сообщений из 1 801 понравились пользователям.
Hi. You can see the Document Directory with the Mathcad Plugin, not in the toolbar but in the SMath document:
