Optimization and fraction problem
Optimization and fraction problem - Wrong sign when trying different optimization and/or fracction convertion for some integrals - Сообщения
#1 Опубликовано: 25.07.2013 18:10:53
Diego Jarrín
Diego Jarrín
7 сообщений из 14 понравились пользователям.
I don't know if this problem has been already reported, but I see some weird behavior with some simple integrals, this happen when I try different kind of optimizations (symbolic, numeric or none) at the same time I try different kind of fraction convertions(decimal, fracction or auto), when I try the eval function I get the same problem.
I attach a file done in the latest stable version (0.96 build: 4868), showing this behavior.
Wrong_sign_1.sm (13,11 КиБ) скачан 1361 раз(а).
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
sergio 26.07.2013 03:55:00, Martin Kraska 26.07.2013 05:22:00
#2 Опубликовано: 26.07.2013 01:09:37
Confirmed in 096_4909
It seems that wrong result will be when the Fractions: Fraction/Auto and Optimization: Numeric
#3 Опубликовано: 20.09.2013 16:07:28
The problem is solved by the Maxima plugin. However, currently you need to explicitly let Maxima take over the functions, otherwise the integrals will work the old way.
[EDIT] Adaption to current state of Maxima plugin
