plot of integral
plot of integral - Сообщения
#1 Опубликовано: 20.10.2015 05:41:02
olik
olik
3 сообщений из 27 понравились пользователям.
Is it possible to plot integral (as function)?
for examlpe
T(x):int(p(xx),xx,0,x)
I changed the function T(x) to matrix with X,Y coordinates, and only the matrix i can plot.
Thak's Olik
#2 Опубликовано: 20.10.2015 06:47:54
Hello olik,
Yes it is possible, look at the screenshot below.
P.S. this post is in the wrong section
#3 Опубликовано: 20.10.2015 07:14:58
Hello olik,
P.S. this post iis in the wrong section
Moved to "Questions"
Davide Carpi 20.10.2015 07:15:00, olik 21.10.2015 07:41:00
#4 Опубликовано: 21.10.2015 08:08:14
olik
olik
Hello.
Thank you. That is great.
However I do not understand the form of function p(xx).
In my opinion there should be
_ _ or a function of x __ p(x) := x-2
_ _ or a function of xx _ p(xx):= xx-2
_ _ ... These options do not work.
And the function p(xx) defined with xx and without x:
- works for plot
_ _ _ _[ plot p(x) does the same as plot x-2 ]
- does not work for evaluating
_ _ _ _[ p(2)= ... "x not defined" ]
Please, can you explain me this?
Thanks Olik
#5 Опубликовано: 21.10.2015 08:28:30
I apologize, was my typo... you're right, p(xx)=xx-2 or p(x)=x-2, doesn't matter... place eval() in the bound of the integral to make the plot working...
ioan92 21.10.2015 13:28:00
#6 Опубликовано: 21.10.2015 13:22:00
"However I do not understand the form of function p(xx)." [Olik]
_____________________________
Like you say: confusing when not used.
The beauty of Smath is like Mathcad [Mathcad being the closest to Smath]
They are both numerical executors and algorithmic evaluators.
Visit "Samples" in few minutes, I will attach an old work sheet that
clarifies/disambigutes the algorithmic construction.
#7 Опубликовано: 21.10.2015 13:47:20
... I have added the successive drivatives from algorithmic construction
Revisit "Samples"
