Variables links in long sheets
Variables links in long sheets - how I link variable from up area of sheet and down area of sheet? - Сообщения
#1 Опубликовано: 25.04.2016 06:54:22
vadim
vadim
I have such problem:
I determine variable X in first string of the first sheet.
Next steps, I had written 2-3 sheets of formulas and see result of calculation far far away from first page.
Can I determine variable Y (last sheet) which determine X value (on start sheet) ?
Like as Excel: a1 cell = a1000; a999 = result; a1000 = value.
Reword: Can we change variable determined on first sheet from variable from last sheet?
#2 Опубликовано: 25.04.2016 06:58:47
Mike Kaganski
Mike Kaganski
Yes, it's possible.
If you determine X early in your document, using Y that isn't yet defined, then later you may define Y as many times as you want, and each time you will get new corresponding X.
X:=Y*2
Y:=5
X=10
Y:=10
x=20
С уважением, Михаил Каганский
vadim 25.04.2016 07:56:00
#3 Опубликовано: 25.04.2016 10:58:34
VladimiR,
Not very clear: as you open Smath you have page 1 [that you name as you wish]
When you call "New page" you will have page 2 [that you name as you wish]
... and so on ...
If page 1 collects successively results from page 2,3,,,
in page 2 write to file the calculated Y
read back [rfile] in page 1 the last calculated value from page 2
In other words: each time you update Y in pages 2,3,,, and [writefile]
in page 2,3,,, it updates the Y stored in file that you read back in page 1.
At the top of each page [work sheet] re-identify for the same file directory.
