The value went beyond the maximum allowed positive number
The value went beyond the maximum allowed positive number - the value went beyond the maximum allowed positive number, error in the solve function - Сообщения
#1 Опубликовано: 12.02.2020 10:38:12
Joki720
Joki720
0 сообщений из 12 понравились пользователям.
Who has faced such a problem, how can it be solved?
Project from below
Poverochnyjj raschjot ehzhektora.sm (84,1 КиБ) скачан 1022 раз(а).
#2 Опубликовано: 12.02.2020 12:07:47
"result above max ..." has no pertinent meaning in your project.
If you attempt "roots" on the numerator only ... "Units don't match"
No need to go further ... zap the units in the project.
#3 Опубликовано: 12.02.2020 12:38:24
Joki720
Joki720
I made a mistake, there should be a solve function, in this place the same error
#4 Опубликовано: 12.02.2020 14:57:49
Same answer: Units don't match.
How can you solve what you can't plot or evaluate ?
#5 Опубликовано: 13.02.2020 07:44:15
You can use the function FindRoot() from the Nonlinear Solvers plugin. The function automatically assigns the solution to the variables.
Единицы измерения здесь не при чем.
2020-02-13 11_38_00-SMath Studio 0.99.7251 - [Poverochnyjj%20raschjot%20ehzhektora.sm_].png
Joki720 14.02.2020 13:06:00
#6 Опубликовано: 14.02.2020 13:09:51
Joki720
Joki720
why do you use 0.2 and 0.5?
#7 Опубликовано: 14.02.2020 13:57:29
Joki,
Martin could have drawn the two curves and graphically estimated the two solutions
#8 Опубликовано: 14.02.2020 14:52:49
Joki720
Joki720
The solution must be automatic, plotting make and evaluating it is not appropriate
#9 Опубликовано: 14.02.2020 19:34:05
OK ... don't plot => find min/max.
Don't you need a road to drive the car from point A to point B ?
#10 Опубликовано: 14.02.2020 22:56:17
Common from ill posed construction.
Consider yellow up until you can plot that system(x,y):= ....
from there it should be solvable.
Poverochnyjj raschjot ehzhektora [zap Units, define the Undefined ...].sm (94,03 КиБ) скачан 858 раз(а).
#11 Опубликовано: 15.02.2020 06:37:16
Go on dreaming. If you are in non-linear systems and you can't find a symbolic solution (Maxima's Solve() got stuck when I tried) then you need numerical procedures for solution. These always need an initial guess (Newton-Raphson) or a search region (bisection). The various procedures just differ in how efficient or how robust they are. Some of them may have quite impressive radii of convergence for particular systems but none has infinite radius for all systems.
Furthermore, there remains the problem of uniqueness of a solution. The only solvers in SMath capable of providing multiple solutions are the
  • solve() finds all solutions of a single equation within a given range
  • Solve() from the Maxima plugin, which finds symbolic solutions.
Blatt21.sm (5,23 КиБ) скачан 1033 раз(а).
#12 Опубликовано: 15.02.2020 12:10:50
Quite right and not enough wrt complex roots.
Cubic solver Exercise.sm (38,97 КиБ) скачан 1005 раз(а).
#13 Опубликовано: 15.02.2020 17:54:43
Always avoid ill posed polynomials.
#14 Опубликовано: 16.02.2020 15:10:14
Jouko Tolonen
Jouko Tolonen
To OP's original question. I did get the same/similar error message on linear interpolation. One of the 5 required values had wrong value. After correcting no issues.
#15 Опубликовано: 16.02.2020 20:47:13
What linear interpolation is doing here ?
If that document makes sense, return with comments.
Poverochnyjj raschjot ehzhektora [solve].sm (95,19 КиБ) скачан 858 раз(а).
#16 Опубликовано: 16.02.2020 23:09:30
I imagine you mean the very last part of the document.
The system looks ill posed, visit Solve Lecture last 3 days.
Poverochnyjj raschjot ehzhektora [solve, spline].sm (104 КиБ) скачан 897 раз(а).
#17 Опубликовано: 17.02.2020 09:35:01
... maybe we can leave it as such ... cleanup ?
Poverochnyjj raschjot ehzhektora [solve, spline].sm (110,44 КиБ) скачан 861 раз(а).
Inst_Isentropic Discharge.sm (173,76 КиБ) скачан 999 раз(а).
