Colebrook Pipe Data
Colebrook Pipe Data - Colebrook Pipe Data - Сообщения
#1 Опубликовано: 21.04.2016 20:35:32
By same token of "Pipe Data", Colebrook Moody has been refactored.
Observe carefully the code to make the 'solve block' survive by
introducing it within a program structure. In this implicit solve,
the block needs an [one] initial value. Same code structure as
it was discovered in Mathcad 8/11 [undocumented].
A splendid piece of Engineering work for publishing and documenting
the project, tracable for the client's archive.
Inst_Colebrook MOODY.sm (16,74 КиБ) скачан 1512 раз(а).
Inst_Colebrook Pipe Data.sm (24,35 КиБ) скачан 1461 раз(а).
#2 Опубликовано: 21.04.2016 21:13:44
Mike Kaganski
Mike Kaganski
kW/hr is non-existent (physically nonsensical) unit of power. Power is measured in kW, and work is measured in kW*hr.
С уважением, Михаил Каганский
#3 Опубликовано: 23.04.2016 01:25:50
Interesting: that's what alll Canadians we pay for 'kWh' consummed.
Billing may vary from Provinces to Provinces
Here is my billing for february 2016
"690 Kwh @ $ 0.0965/kWh"
My kW/hr is user to conform Q[T/hr] to deconfuse unit user confused.
#4 Опубликовано: 23.04.2016 01:32:22
... typos, updated, on-fly calculator added.
JeanInst_Colebrook Pipe Data.sm (60,85 КиБ) скачан 1451 раз(а).
#5 Опубликовано: 23.04.2016 03:36:54
Mike Kaganski
Mike Kaganski
Yes. kWh = kW*hr. This is unit of energy. Energy is integral of power by time, i.e. mean power multiplied by time. Power is measuted in kiloWatts, time in hours.
#6 Опубликовано: 23.04.2016 09:43:20
What you say is right, but not for design Engineer.
The Engineer wants to know the "POWER RATING" of the
motor to push Q[T/hr] via the pump it activates.
That's what the "Pipe Data" answers for those in that stuff.
Just introduce the 'r' efficiency factor from the supplier
of the 'MotorPump'.
