1 страниц (8 вхождений)
How to do polar form like mathcad? - polar form - Сообщения
I have just started to use Smath and am liking it so far.
I could not figure out how to enter values in polar form with its angle? say 100/_60deg, i.e. a magnitude of 100 and a degree of 60.
On Mathcad the polar operator is in operator -> engineering menu. I can't find similar in smath but everything else I am at home with.
I can see there is a polxy function but it is not quite the same?
Thanks
Thanks
Thanks uni for that. I tried it and it seems to work - but is it possible that i don't key in the "degree" sign and still get the same result? i.e. the polar form of 100/_60deg = 50 + j86.6.
If I dont put the degree sign it will return -95.24 -30.48i which is a different result.
Thanks
WroteWroteI tried it and it seems to work - but is it possible that i don't key in the "degree" sign and still get the same result? i.e. the polar form of 100/_60deg = 50 j86.6.
Thanks! that works well.
How would I convert from polar to rectangular but using the variable instead?
say I have this:
pol(m,a):= m.exp(a.pi/180*i)
V:=pol(1,10) = 0.9841 + 0.1736*i
I:=V/200 = 0.0049 + 0.0009*i
I want to display I in a polar form.
I can use xypolto but not so convenient.
How do I do xypol2(I) = ?
WroteInteresting thanks for that. I will experiment with that.
You can have it Class Room style.
Cheers from Up There to Down Under ... Jean.
Polar Circle.sm (5,84 КиБ) скачан 1282 раз(а).
