Rom2Arab
Rom2Arab - Arab2Rom - Сообщения
#1 Опубликовано: 18.10.2023 22:06:10
Valery Ochkov
Valery Ochkov
67 сообщений из 708 понравились пользователям.
Why doesn't the cycle end?
See please the attachRome-Arab.sm (40,3 КиБ) скачан 1496 раз(а).
#2 Опубликовано: 19.10.2023 00:53:00
Oscar Campo
Oscar Campo
Really it's a very strange bahavior (a bug ?), because the value of variable n is cleared when function returns from Arab2Rom()
So, a solution is to use functions fwrite() and rfile() to save the value of n on a file as a memory:
See the atachment with the solution: Rome-Arab SOLVED.sm (41,21 КиБ) скачан 1495 раз(а).
best,
Oscar
Valery Ochkov 19.10.2023 01:08:00
#3 Опубликовано: 19.10.2023 01:30:20
Hi. In Arab2Rom(n) you modify n.
That's not good practice. This is a workaround for such cases.
Valery Ochkov 19.10.2023 01:46:00, Oscar Campo 19.10.2023 01:46:00
#4 Опубликовано: 19.10.2023 01:42:23
Valery Ochkov
Valery Ochkov
Thanks!
But this have an error too!
Rom2Arab.sm (293,29 КиБ) скачан 1478 раз(а).
#5 Опубликовано: 19.10.2023 01:52:56
Thanks!
That's another function, not similar with the others above. Here the problem is the origin in Mathcad for strings. Try to set ORIGIN = 1 in Mathcad and rewrite the code.
#6 Опубликовано: 19.10.2023 02:13:24
Valery Ochkov
Valery Ochkov
Thanks!
#7 Опубликовано: 19.10.2023 02:43:57
This is one way.
Valery Ochkov 19.10.2023 02:49:00
#8 Опубликовано: 19.10.2023 02:49:12
Valery Ochkov
Valery Ochkov
This is one way.
Thanks,
send please the sm-file!
#9 Опубликовано: 23.10.2023 00:30:24
Valery Ochkov
Valery Ochkov
My salary in 1980
ATM-SU.sm (6,29 КиБ) скачан 1484 раз(а).
#10 Опубликовано: 23.10.2023 01:34:42
If I remember correctly, 1988 a bottle of vodka (0.5l) was 3 rubles (if you got it at all, it was the time of prohibition - сухой закон). Therefore the 3-ruble-notes.
Valery Ochkov 23.10.2023 02:31:00
#11 Опубликовано: 23.10.2023 02:24:31
Valery Ochkov
Valery Ochkov
2 рубля 87 копеек = 2.75 vodka + 0.12 bottle.
Three constants of soviet students 3.14, 2.87, 2.72
#12 Опубликовано: 28.10.2023 16:11:54
Valery Ochkov
Valery Ochkov
There are also zeros in Roman numerals. See my photo from Greenwich.
And four is written this way IIII and not that way IV because there are only 12 and not 13 digits.
