Explicit values of formula's variables (partial evaluation) (equivalent of ->explicit as in Mathcad)
Explicit values of formula's variables (partial evaluation) (equivalent of ->explicit as in Mathcad) - Equivalent in Smath Studio of this operator in Mathcad ->explicit. - Сообщения
#1 Опубликовано: 05.02.2015 23:17:40
jos.md
jos.md
I would like to know how in Smath Studio I could show the Explicit values of formula's variables.
(It would be a partial evaluation of the formula)
Example:
a=1
b=2
c=a+b
c->1+2 (This is the evaluation with values)
c=3
This is posible in Mathcad using the evaluation operator with the word "explicit,variables" (I attached some examples). What is the equivalent function or operator in SMath Studio?
(Commentary: This in important for me, because I have had to teach Math and Physics, and for students it is better and necessary to show step by step the resolution of a problems and exercices. Also, to make manuals and reports in this education area).
In advance, thank you very much.
-Josué Mtz-
#2 Опубликовано: 06.02.2015 05:04:06
It is relatively easy. Just use Optimization->None on the region when using numerical or symbolical equal to after the formula.
Dhrmendu Mandal 08.10.2020 05:54:00
#3 Опубликовано: 06.02.2015 13:42:43
jos.md
jos.md
Thank you very much. That's exactly what I was searching.
THANK YOU.
#4 Опубликовано: 07.02.2015 05:22:27
Basile
Basile
8 сообщений из 172 понравились пользователям.
Yes, but now we need to have the numerical result.
The only way I can see it done is by repeating the variable again below. Then by default SMath does numerical evaluation.
I would suggest, for practical science and engineering calculations, to be able to solve the problem in three steps
1. The formula
2. Substitution of variables with units
2. Numerical result and unit
Basile
Serg 19.10.2018 06:35:00
