String to Variable Name (str2var)
String to Variable Name (str2var) - Сообщения
#1 Опубликовано: 31.12.2022 02:33:45
Mark R Harris
Mark R Harris
5 сообщений из 90 понравились пользователям.
Is there a function or method that would allow a string (or variable name) located in a matrix element to be used as the name to define a variable?
Something like this:
Thank you!
#2 Опубликовано: 31.12.2022 04:28:45
Файл не найден. Файл не найден.
Mark R Harris 31.12.2022 06:43:00, NDTM Amarasekera 31.12.2022 10:10:00, overlord 01.01.2023 15:20:00, sergio 31.12.2022 08:09:00
#3 Опубликовано: 31.12.2022 06:43:07
Mark R Harris
Mark R Harris
Thank you so much uni!
#4 Опубликовано: 01.01.2023 12:51:50
Laurent Fournier
Laurent Fournier
9 сообщений из 66 понравились пользователям.
WOW!!!
#5 Опубликовано: 02.01.2023 06:31:00
You can also use the Assign() function of the Maxima Plugin (this should work even without Maxima installed).
It converts boolean equations into assignments.
In the case of strings you still need to apply str2num()
Assign.sm (4,75 КиБ) скачан 1353 раз(а).
sergio 02.01.2023 07:35:00, Mark R Harris 02.01.2023 17:02:00
#6 Опубликовано: 04.01.2023 20:02:47
Mark R Harris
Mark R Harris
Some odd behavior here. When the "=" evaluation is removed the Assign() function breaks:
Assign odd behaviour.sm (3,14 КиБ) скачан 1333 раз(а).
Any thoughts?
I'm hoping to be able to assign multiple variables from a matrix like this:
Assign For Loop Broken.sm (5,11 КиБ) скачан 1292 раз(а).
#7 Опубликовано: 04.01.2023 21:47:22
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
a small workaround, could be to place the for inside a line command and return a false token value, it is not very clean but it works as far as I can see.
I think the assign command is not evaluated immediately, but has a delayed evaluation, which somehow only takes place after using the "=" symbol.
Mark R Harris 04.01.2023 22:04:00
#8 Опубликовано: 05.01.2023 11:30:01
Assign() is a useful function and it doesn't need Maxima as you have indicated.
I don't (can't) use Maxima but I need Assign() sometimes.
And its codes have zero relation with Maxima functions.
This is why I suggested sometime ago that it could have relocated in another collective plugin.
CustomFunctions plugin is a good candidate for this purpose.
But I am not persistence, it is what it is.
Author of these plugins choose it this way.
Mark R Harris 05.01.2023 18:24:00
#9 Опубликовано: 05.01.2023 16:57:04
Any thoughts?
Two hints:
- The Assign function needs to be executed in order to do it's work, either by assigning the result to some dummy variable or by requesting display of the result.
- You don't need a loop, Assign() can handle vector arguments
Blatt10.sm (5,31 КиБ) скачан 1377 раз(а).
#10 Опубликовано: 05.01.2023 17:22:41
In general I don't care where Assign() is defined. It is in the Maxima plugin, because I needed a neat way to make use of results from Maxima functions like algebraic or ode solvers.
Yet I don't think that it would be a good idea to remove functions from plugins, because this would break the dependency management of existing sheets.
I don't know what happens if the same function is defined in multiple plugins. Would SMath crash? If not, which definition is used if both plugins are installed? One would see this in the dynamic help, but how to control?
BTW, I think that some day I'll revisit the Maxima plugin and if I get some help with a linux development tool chain and work flow I could perhaps make the plugin work also under linux. But that would require at least two months of full time work without distractions, because I would need to learn C# anew from scratch.
If someone is a master in C# I am happy to assist in refactoring and bug fixing of the plugin by providing the specifications and unit tests.
I'd be more comfortable with python or javascript but to my knowledge these aren't options for making plugins.
Mark R Harris 05.01.2023 18:25:00
#11 Опубликовано: 06.01.2023 02:15:05
Hi. This could be another option.
MyAssign 2.sm (10,52 КиБ) скачан 1353 раз(а).
7 пользователям понравился этот пост
⚜ Kenny Lemens, P.E. ᵂᴵ 27.02.2023 12:19:00, Вячеслав Мезенцев 06.01.2023 07:07:00, NDTM Amarasekera 06.01.2023 12:57:00, sergio 06.01.2023 14:23:00, churichuro 06.01.2023 16:19:00, bdrunagle 06.01.2023 16:21:00, Mark R Harris 06.01.2023 16:41:00
#12 Опубликовано: 06.01.2023 16:25:18
churichuro
churichuro
@Razonar, as usual with you, you give imaginative and useful solutions, it's great when people share their knowledge and help others, and with such a high technical level. thanks and congratulations.
I have a folder on my computer exclusively for the spreadsheets you share.
Mark R Harris 06.01.2023 17:15:00, Alvaro 06.01.2023 23:10:00
#13 Опубликовано: 06.01.2023 16:42:15
Arie
Arie
In the event you may want to add descriptions to these definitions... a related thread:
https://en.smath.com/forum/yaf_postst23228_Assign-Description-to-Variable.aspx
It's a work around, but potentially useful.
Alvaro 06.01.2023 23:10:00, sergio 07.01.2023 07:09:00, Mark R Harris 06.01.2023 16:50:00
#14 Опубликовано: 06.01.2023 16:43:00
Mark R Harris
Mark R Harris
Yes indeed. Likewise. What churichuro said!
#15 Опубликовано: 06.01.2023 23:11:34
Thanks guys. I sincerely appreciate that.
