Matrix multiplication
Matrix multiplication - Сообщения
#1 Опубликовано: 29.11.2019 00:48:59
Hi. Something is wrong here, in both MProd functions, but can't figure what is it.
Thanks in advance.
mprod bug.sm (12,4 КиБ) скачан 1569 раз(а).
#2 Опубликовано: 30.11.2019 22:06:11
Hola, Alvaro.
Not sure what you are attempting to do
1. Multiply a two cols matrix by a single number [2D rotation].
2. Multiply a 3 cols matrix by a 3x3 matrix [3D rotation]
3D rotation from Smath 3D [3 cols] creator.
Both exemplified Annalema.
3. RGB nxm matrix rotation [example Venturi RGB]
4. Square matrix [nxn] rotation [example Hyper-Surface]
Thanks Alvaro ... Jean
Image Rotate Matrix.sm (41,7 КиБ) скачан 1499 раз(а).
Analemma.sm (140,74 КиБ) скачан 1536 раз(а).
Image Rotate RGB.sm (348,3 КиБ) скачан 1491 раз(а).
#3 Опубликовано: 02.12.2019 13:20:00
MBe
MBe
2 сообщений из 21 понравились пользователям.
Thanks in advance.
Hello Alvaro, I can't explain the problem, but I see that it originates from the way arguments are passed to MDot.
See attachment, writing arguments directly into MDot gives correct result, passing through row() and col() gives an "a not defined" error.
It seems that using row() and/or col() a numerical evaluation is triggered, even if the region is marked as "Symbolic".
Sorry, I can't give a better explanation.
Marco
mprod_bug_MBe.sm (16,3 КиБ) скачан 1532 раз(а).
P.S.: for matrix multiplication also index notation can be used, which works pretty nice in Smath.
I attach here an example, just in case it could be useful to somebody.
I wonder if Einstein notation could be implemented in Smath, so that summation symbols could be implicitly applied on mute indexes... maybe this is aking too much...
IndexNotation.sm (11,99 КиБ) скачан 1524 раз(а).
Alvaro 03.12.2019 07:12:00
#4 Опубликовано: 02.12.2019 16:11:18
BTW: Thanks Marco for the Scilab/Smath Vector Intersection code.
I encountered many instances row(,,) col(,,)
that must be assigned as an algo
My understanding is like this:
1. Assume Alvaro has an 'n col vector A'
2. He wants to multiply any col or all [even in mixed order]
3. Multiplication by a number is immediate.
4. Multiplication by 'L length vector' needs a vectorize algo.
In the soon/next posted Rainbow it is ± what we are doing.
Instead of multiplying, we linterp.
#5 Опубликовано: 03.12.2019 07:17:24
Thanks in advance.
Marco
Hi Marco. Thanks very much for your appointments. I go to take them in consideration for see the best way to extend dot product for some simple manipulations with symbolic algebra and taking the conjugate transpose instead the second argument.
#6 Опубликовано: 03.12.2019 07:20:35
Hola, Alvaro.
Hi Jean. Just make very simple math, checking how to write the elemental things in SMath. If not, how to write something more complex?
#7 Опубликовано: 04.12.2019 07:19:33
Marco
Hi. Enogh to know that problem it's in row and col functions. Even I can't write the code for them, seems to be solved the issue rewriting length function.
mprod_workaround.sm (7,99 КиБ) скачан 1482 раз(а).
Same solution it's used for Lagrange equations with vectors.
#8 Опубликовано: 04.12.2019 10:34:09
Alvaro ... is that what you are looking for ?
Utilities Matrix Product[X,Y].sm (16,63 КиБ) скачан 1277 раз(а).
#9 Опубликовано: 04.12.2019 12:30:11
MBe
MBe
Marco
Hello everybody. More on the strange behaviour of function "lenght()". See attached.
Anybody can explain why lenght() does not accept the evaluation operator?
Thanks
Marco
Lenght_MBe.sm (8,94 КиБ) скачан 1486 раз(а).
P.S.: Sorry, my mistake. Do not consider this post. I just mispelled the function...
#10 Опубликовано: 04.12.2019 15:00:26
Maybe I don't understand ...
