mm to m
mm to m - I want other - Сообщения
#1 Опубликовано: 15.02.2016 06:02:40
Jonny
Jonny
i have a lot of problems with units
if i want mm the program makes m
if i want N/mm2 the program makes Pa
is it possible to defin it ?
how do you do it ?
#2 Опубликовано: 15.02.2016 06:33:02
Hello Jonny,
Units in results are by default in base units. You can set the more appropriate units for the single result writing in the rightmost placeholder (wiki: units)
If you are interested to have default output units you can register in the Bug Tracker System and vote SS-1
#3 Опубликовано: 15.02.2016 12:23:26
So nice your demo , Davide ! Thanks for that vivid Smath tutorial.
Hello Jonny:
"Uconeer" is a freeware unit converter from "Katmar Software"
Very useful for Engineering works. From same "Katmar Software"
you can download "Wasp" [Water Steam Properties].
