XY Radial Grid
XY Radial Grid - XY Radial Grid - Сообщения
#1 Опубликовано: 06.11.2016 10:21:09
There is a bit more in the work sheet [Nsectors, inner radius].
More can be done... for instance: if the XY Lissajous would be
a closed isoline around a mountain, it would easy to adapt this
basic construction ... adjust the great circle, inner circle.
You can add/size the inner circles.
2D Radial Grid.sm (24,45 КиБ) скачан 1520 раз(а).
#2 Опубликовано: 06.11.2016 11:48:44
... ont his one: added noise on the inner circle.
2D Radial Grid.sm (42,48 КиБ) скачан 1488 раз(а).
#3 Опубликовано: 06.11.2016 19:09:08
Fridel Selitsky
Fridel Selitsky
1.sm (8,6 КиБ) скачан 1455 раз(а).
#4 Опубликовано: 06.11.2016 22:14:54
Hello Ber7,
Thanks for that one. I guess that's how they size cauliflower heads !
