1 страниц (4 вхождений)
XY Radial Grid - XY Radial Grid - Сообщения
There is a bit more in the work sheet [Nsectors, inner radius].
More can be done... for instance: if the XY Lissajous would be
a closed isoline around a mountain, it would easy to adapt this
basic construction ... adjust the great circle, inner circle.
You can add/size the inner circles.
2D Radial Grid.sm (24,45 КиБ) скачан 1520 раз(а).
Hello Ber7,
Thanks for that one. I guess that's how they size cauliflower heads !
