1) Entering Text 2)Dark Mode (Black background with white text)
1) Entering Text 2)Dark Mode (Black background with white text) - Сообщения
#1 Опубликовано: 06.12.2021 19:56:36
Fran Lee
Fran Lee
1 сообщений из 44 понравились пользователям.
1) If I just start typing text...
Is that the same as first clicking Insert > Text Region... and then typing?
If not what is the difference?
2) Regarding Dark Mode aka Dark Theme...
I searched forum and saw some discussion on it but not the "click path" to get there... if it exist.
I also looked in...
File > Properties
File > Page Setup
Tools> Options
Insert > Background
The Question: Is there a Dark Mode and if where do I click to get it?
Thanks for any help.
#2 Опубликовано: 07.12.2021 09:36:42
1. As you start typing, it's maths. Press space to continue text.
2. Enter directly text region, type "
#3 Опубликовано: 07.12.2021 09:42:10
Create your dark back background from personal pre-assigned background
That is to apply to any maths/text region.
black [1,1,1]
white [254,254,254]
#4 Опубликовано: 07.12.2021 09:48:30
598 сообщений из 1 379 понравились пользователям.
It is same, there is no difference with insert text & direct typing.
As long as you don't write something that will alter the text into an expression.
SMath respects to your OS's theme. At least this is what it is on Linux.
Canvas is always white background, black text. This is by intended I guess.
It should be same in windows also. Don't mind Jean's answer, he didn't get what you meant.
If an experienced user who understand the question can answer it, it will be more descriptive.
However dark theme makes some text of menus or properties not be readable.
Main dark themes are not usable, so I use light theme due I use dark theme on system-wise.
This is of course the reason of theme colors, not smath's.
Regards.
#5 Опубликовано: 07.12.2021 12:01:36
Is that what you mean by Dark Mode ?
#6 Опубликовано: 07.12.2021 13:02:38
1 554 сообщений из 1 864 понравились пользователям.
sergio 07.12.2021 13:22:00, Davide Carpi 07.12.2021 15:00:00
#7 Опубликовано: 07.12.2021 14:03:32
Sorry, I won't dare publish that f...n crap !
#8 Опубликовано: 07.12.2021 15:10:14
1 442 сообщений из 2 935 понравились пользователям.
Dark/Night mode usually is intended for editing, not for publishing. While activated, what is printed black-on-white is rendered white-on-black on the screen. It become a little bit trickier to handle when colors are involved, since lighter color looks better on the "virtual" (dark) background but not always on the (white) paper... like in Autocad when you have a layout view on white background while the drawing is made on the classic black canvas...
However as long as something it is optional, nothing wrong to me. There are plenty of presentations made on dark backgrounds, and are often more readable on screen/live projection than the white ones. A pain to print and read on paper? Absolutely.
