Plug-ins Forbidden - after new Update
Plug-ins Forbidden - after new Update - Version 1.1 build: 8763 - Сообщения
#1 Опубликовано: 11.01.2024 21:48:22
Thilo Schönherr
Thilo Schönherr
since the new Update i can't update or install Plug-ins. Is it because of the basic version i am using or is there on program error?
#2 Опубликовано: 11.01.2024 22:19:45
601 сообщений из 1 382 понравились пользователям.
Re-login to your account from Smath.
Valid only if account is sufficient.
That should do the trick.
Thilo Schönherr 12.01.2024 01:29:00
#3 Опубликовано: 11.01.2024 23:38:42
since the new Update i can't update or install Plug-ins. Is it because of the basic version i am using or is there on program error ?
Yesterday, I was Solver 30405
Error messages eternized about Maxima not available
Shut the box, restart Smath ... Oh! new version.
Open the dialog box, red down all conditions,
most important down to last line
Accept ... download ... install
All fine ... 30405 is now "1.1.8763.0"
#4 Опубликовано: 12.01.2024 01:30:56
Thilo Schönherr
Thilo Schönherr
Thank you @overlord. I had to repair the program and now it works.
But one plugin (TableRegion) don't work. Does the TableRegion only works in pay-accounts?
#5 Опубликовано: 12.01.2024 19:46:28
My Table region works "1.1.8763.0"
#6 Опубликовано: 12.01.2024 22:08:46
His table region WAS NOT WORKING.
Oscar Campo 13.01.2024 20:28:00
#7 Опубликовано: 15.01.2024 19:06:27
Hello [userlink]Thilo[/userlink]
The plugin should work for everyone in the latest SMath Studio, this is the version that should be listed in your extensions manager.
#8 Опубликовано: 31.05.2024 00:25:16
francesco rapuano
francesco rapuano
15 сообщений из 38 понравились пользователям.
Hi Davide,
sorry for bothering but this afternoon I decided to updated Smath Studio to the last release and Table Region,Slider Region, RAdio Button List Region , Numeric up down and Path Picker Plugin don't load anymore at sturt up as previously accomplished.
Do you know ( or anyone else too) how to address this issue ?
Thanks in advance foryour help and best regards
Franco
#9 Опубликовано: 31.05.2024 12:20:12
francesco rapuano
francesco rapuano
This is just to inform you all that after re-installing from scratch Smath STudio the issue reported was fixed.
Franco
Davide Carpi 31.05.2024 15:41:00
