Excel or spreadsheet region plug in
Excel or spreadsheet region plug in - Excel or spreadsheet region plug in - Сообщения
#1 Опубликовано: 28.06.2019 18:44:27
aviateCar
aviateCar
0 сообщений из 16 понравились пользователям.
Hi Gurus:
Does Smath has Excel or Spreadsheet region plug in function?
I am trying to make a table to calculate area moment to inertia but dont know how to make it work.
Thanks,
Chris
#2 Опубликовано: 28.06.2019 21:31:53
You just need to know the maths of each col,
and construct the Smath matrix in descending rows
... No need for Excel
Visit Colebrook Pipe Data.
Inst_Colebrook MOODY.sm (19,13 КиБ) скачан 1169 раз(а).
Inst_Colebrook Pipe Data.sm (61,58 КиБ) скачан 1172 раз(а).
#3 Опубликовано: 29.06.2019 04:30:09
fedeghi
fedeghi
25 сообщений из 112 понравились пользователям.
Hi Gurus:
Thanks,
Chris
You can also try Davide Carpi "Table region" plugin.
It is another option to list the results of your calculation in a good looking way.
Very convenient for publishing purpose
Of course, as Jean suggested, every calculation should be prepared using matrix approach.
#4 Опубликовано: 29.06.2019 16:09:55
CBG
CBG
Something like this?
Tabla_Momentos.sm (57,1 КиБ) скачан 1196 раз(а).
Andrey Ivashov 30.06.2019 19:28:00
#5 Опубликовано: 02.07.2019 12:30:34
aviateCar
aviateCar
Thank you! Will try that later.
#6 Опубликовано: 02.07.2019 12:32:06
aviateCar
aviateCar
Hi Gurus:
Thanks,
Chris
Thank you! I agree table is so easy to read in reports.
#7 Опубликовано: 02.07.2019 12:33:07
aviateCar
aviateCar
Exactly what I was looking for! Thank you so much! This function is going to be really useful for me.
#8 Опубликовано: 02.07.2019 17:01:41
aviateCar
aviateCar
Hi Carlos:
This happened while I was working on it.
This red cross took all of the work after the plug-in away.
Have you experienced this?
How can I fix it?
Thank you!
Chris
#9 Опубликовано: 02.07.2019 18:33:13
CBG
CBG
Hi Carlos:
How can I fix it?
Thank you!
Chris
Hi Chris
Yes, I've had that kind of problem, and it happens when the Plugin is not recognized or is not installed.
You have to install the plugin or update it.
Verify that your version of Smath Studio is compatible with the version of the Table Region Plugin.
#10 Опубликовано: 02.07.2019 18:48:27
aviateCar
aviateCar
Hi Chris
Hi Carlos:
Thank you so much for the response.
How do I know if they are compatible?
I installed the plugin from within the extension manager (from online gallery) and assume they are compatible?
Thanks,
Chris
#11 Опубликовано: 02.07.2019 19:05:37
Seems the right version. You can guess it is the right version by the 3rd 4-digits number, that should be similar and usually the same or slightly greater in the plugin. You can have more hints by checking the release dates. If you installed it by the internal release manager or by opening a worksheet there shouldn't be conflicts. I don't know what happened, if I have time tomorrow I'll try to make some tests...
#12 Опубликовано: 02.07.2019 19:09:04
CBG
CBG
Hi Chris
The green color and the tilde indicate that it is compatible.
When the plugin is not compactible it is shown as the following example.
Why not try the latest version of Smath Studio?
#13 Опубликовано: 02.07.2019 20:18:31
aviateCar
aviateCar
Thank you for walking me through this procedure David!
Stress Analysis-Table Region Failed.sm (152,05 КиБ) скачан 1135 раз(а).
Attached is the subjected worksheet. Please review.
Thanks again!
Chris
#14 Опубликовано: 02.07.2019 20:22:06
aviateCar
aviateCar
Hi Chris
Thank you Carlos!
Its a work computer and it takes time for IT to respond any request.
I ll try it on my own computer, a mac tho...
Thanks again!
#15 Опубликовано: 04.07.2019 05:33:01
fedeghi
fedeghi
Thanks again!
Chris
Hi Chris, I have downloaded and opened your file, same problem on my PC.
In any case, Table plug-in is still working correctly for me, when opening other files.
So, I'm afraid that in your case the bug is not in the plug-in installation itself, but in the calculation file that maybe got corrupted in some way?
Strange that when I open you file, first page is completely blank, second is a snapshot of a figure/book, third apparently contains nothing more than one declaration, some text and the mentioned error "red box".
Is there no other maths? Or did it get deleted by you? Or maybe by the bugged table?
Bye
#16 Опубликовано: 04.07.2019 11:08:00
For what is worth: stable SS 6179 from Carlos 7019
#17 Опубликовано: 04.07.2019 12:02:44
aviateCar
aviateCar
Thanks again!
Chris
Bye
Hi Fedeghi:
Thank you so much for trying to help.
I deleted the first page. When the "red box" appeared, it took about 4 pages of content away. Only 2 pages are related to the table region, the rest of them were independent.
Stress Analysis-Moment of Inertia Calculation.sm (27,27 КиБ) скачан 1133 раз(а).
Here is the "table region" as an independent file. It worked fine until I inserted it into the main file.
Thank you!
Chris
#18 Опубликовано: 04.07.2019 12:11:05
aviateCar
aviateCar
Maybe thats the reason... Carlos used a newer version to prepare it but I used the older one to modify it, but on the other side, they are all math!
#19 Опубликовано: 04.07.2019 17:07:26
CBG
CBG
Here is a version of the file in SS-7030 including a sheet that is visible from the file that failed
Stress Analysis-Moment of Inertia Calculation_V7030.sm (167,23 КиБ) скачан 1231 раз(а).
#20 Опубликовано: 04.07.2019 17:16:19
aviateCar
aviateCar
Thank you Carlos!
There is supposed to be 2 more pages of data. I assume when the error happens it removed everything after it.
Anyways, I have re written everything and so far no issues.
Thanks again for your help!
Chris
