How to set worksheet size, headers and footers size?
How to set worksheet size, headers and footers size? - How to set worksheet size, headers and footers size - Сообщения
#1 Опубликовано: 23.11.2020 04:21:00
veb
veb
1 сообщений из 38 понравились пользователям.
Hello!
I am trying to issue the entire calculation in SMATH (according to GOST with frames). I add the frame as a background to the whole worksheet, like a picture. It is not possible to correctly line up the location of the text, since the dimensions of the header and footer do not allow.
#2 Опубликовано: 23.11.2020 09:28:50
2 335 сообщений из 4 031 понравились пользователям.
Группа: Super Administrator
Hello.
Use "File" > "Page Setup" from main menu.
#3 Опубликовано: 24.11.2020 03:23:18
veb
veb
Hello.
I did not see, although I searched everywhere.
Thank you very much!
#4 Опубликовано: 24.11.2020 04:58:29
shiju
shiju
1 сообщений из 7 понравились пользователям.
Go to "File" > "Page Setup"
There you can set up the size of page(s), orientation of the page, width of margin, Header/Footer, etc.
You may refer the picture shown.
Page setup-1
Page setup-2
Thanks and regards
Shiju
