[SS-2267] ImportData and dec separator
[SS-2267] ImportData and dec separator - Сообщения
#1 Опубликовано: 26.03.2015 17:53:37
I want to read a text file using ImportData() and can't understand the effect of the dec separator setting (second argument)
The first version with correct specification does not work.
The other versions with default or wrong specification do work. But they don't work on some other computers.
This is the contents of the file:
Показать спойлер
This is the system information
Показать спойлер
As this might largely system dependent, I would like to get this tested by others before committing a bug report in the bts
importdatabug.sm (7,93 КиБ) скачан 1399 раз(а).
#2 Опубликовано: 27.03.2015 10:49:41
Same result as your if I use comma as decimal separator and semicolon as argument separator
the result below is if I use period as decimal separator and comma as argument separator
Показать спойлер
