Copy and paste from excel as image
Copy and paste from excel as image - Сообщения
#1 Опубликовано: 28.06.2021 01:04:52
bugreportaccount
bugreportaccount
When selecting excel cells and pasting into smath it used to paste as a nice resolution image which is superior to using snipping tool. Now when I do it, I get a text box of the text somewhat formatted. Was this a change that was implemented intentionally or maybe i'm using a plugin im not aware of? Is there a way to restore pasting images by copying and pasting from excel as I do this quite often.
ThX
#2 Опубликовано: 28.06.2021 12:17:12
1 124 сообщений из 1 796 понравились пользователям.
Hi. As workaround you can try the following:
- Create a "Picture" in SMath, from the menu or with Ctrl-T
- Paste on it the excel region
- Right click on the Picture and unselect "Edit".
Now you can resize the image as any other embeded image in the document.
#3 Опубликовано: 28.06.2021 13:40:24
WinGrab is 1/1 pixel RGB
Naive way in few steps ... 1/1 RGB
PrintScreen, Paste in Paint, Select/Copy, Paste in Smath
