.sm File corrupted with no error message
.sm File corrupted with no error message - 消息
#1 已发布: 2017/5/15 16:43:52
sdfms
sdfms
0个赞,共3个帖子。
I have done a calculation on a retaining wall, which suddenly has become corrupted. Smath will open the file, but won't display most of it. The last pages are missing, and there is just a red error dot on the last page (see pic)
显示剧透
Stottemur.sm (491.35 KiB)已下载 1439 次。. Is it somehow possible to restore this?
#2 已发布: 2017/5/15 17:14:58
1,362个赞,共2,276个帖子。
Here you are:
Stottemur_Kr.sm (491.24 KiB)已下载 1405 次。
#3 已发布: 2017/5/15 17:17:39
sdfms
sdfms
0个赞,共3个帖子。
That is amazing, thank you so much, you really saved me a lot of time there!
#4 已发布: 2017/5/15 17:50:11
983个赞,共6,866个帖子。
Smath is capricious with some plugins. If an image region has not completed
[right or wrong], most likely Smath will not save and will file 0 kb. That
is because an image region is resident in the work sheet, therefore: if
not done nothing to save. In your document, you had an empty "Writer region"
in red. Delete it, bingo => your document is 100 % there.
#5 已发布: 2017/5/16 13:06:11
sdfms
sdfms
0个赞,共3个帖子。
Thanks for the explanation. Is there any way to easily find empty regions like that?
#6 已发布: 2017/5/16 15:11:45
1,443个赞,共2,936个帖子。
It is an issue solved with the latest beta version, so you can upgrade and simply open the file with that version; if you won't update to a beta version you can still use the beta just to to open and save the file, then open this file with your stable SS.
#7 已发布: 2017/5/16 20:34:31
983个赞,共6,866个帖子。
Is there any way to easily find empty regions like that ?
"empty region": you mean an unspecified/not filled region.
Up to now, I never noticed Smath sending some region anywhere
in the work sheet. Mathcad 11 would [once in a while] send
region [usually a dead region] pages'sss down, pages'sss right.
In Smath, past the last region, next page is blank [blue].
