Unified Soil Classification System USCS
Unified Soil Classification System USCS - spreadsheet - 消息
#1 已发布: 2023/8/31 16:30:44
Fabian Valencia Villaquiran
5个赞,共3个帖子。
Attached is a spreadsheet to classify the soil according to USCS and the granulometric curve is plotted by sieving.
Please upload any improvements done to this file and post if any mistakes are found or if you have any suggestions.
This is the original code.
USCS1.sm (101.6 KiB)已下载 1869 次。
This is the original code with another particle-size distribution
USCS.sm (103.17 KiB)已下载 2274 次。
Below in another post it is updated with a better presentation of the granulometric curve.
3位用户喜欢此帖子
João Felipe Seráfico Melo 2023/8/31 23:41:00, Alvaro 2023/9/1 01:11:00, sergio 2023/9/1 05:03:00
#2 已发布: 2023/9/6 10:14:07
983个赞,共6,866个帖子。
Fit & explorer ... Jean
USCS fit Granulometry.sm (21.61 KiB)已下载 1788 次。
#3 已发布: 2023/9/7 01:23:17
5个赞,共3个帖子。
Thank you so much,
I added the logistic sigmoid function you made to the initial code and it compare with and without the fit. In addition to the initial curve, I graphed it using the Zed Graph, where it can be better appreciated using a semilogx graph
USCS-fit-Granulometry.sm (175.97 KiB)已下载 1681 次。
#4 已发布: 2023/9/8 15:07:51
983个赞,共6,866个帖子。
Thank you so much,
Thanks as well, very educative.
A large suite of math codes added
Cheers ... Jean.
Project USCS fit Granulometry.sm (90.24 KiB)已下载 1798 次。
