Stable: SMath Studio 0.98.6179 (01 December 2016)
Stable: SMath Studio 0.98.6179 (01 December 2016) - 消息
#1 已发布: 2016/12/1 17:36:37
2,344个赞,共4,057个帖子。
组: Super Administrator
New stable SMath Studio 0.98.6179 available
Tiny, powerful, free mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into 38 different languages. Application also contains integrated mathematical reference book.
Changelog (against to the previous stable release SMath Studio 0.98.6128)
  • [SS-2413]: Situations with displacing Regions on Worksheet open fixed;
  • [SS-2407]: UnitsOf function improved to fix negative results and support sys(..) as an argument;
  • [SS-2309]: Stack/Augment improved to accept numbers/strings in any position (systems are managed as scalar numbers);
  • Application loading speed improved;
  • Numeric power operation improved to handle extremely small numbers correctly;
  • Behaviors to work with collapsed Areas significantly improved on Copy/Paste/Ctrl+drag;
  • Delete/Cut operations fixed when working with Collapsed Areas;
  • Fixed error happened in worksheet history in some cases (it was impossible to restore deleted region with ReDo);
  • SMath Viewer improved to accept user input of exponential notation and imaginary numbers;
  • Page Counter tooltip now shown over all other visible UI elements;
  • All Regions based on RegionHolder improved to be correctly shown on focus when they are not fully visible on the screen;
  • Back-compatibility of col/row functions calculation improved;
  • Silent mode: exceptions happened on several configurations fixed;
  • Cloud: Fixed issues appears on using Backspace/Delete/Enter to move Regions under cursor up or down on the Worksheet;
  • Loading screen is now shown on top of other windows;
  • Interface translations updated;
  • Refactoring.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Free Download
Tutorial
Other files
12位用户喜欢此帖子
Mike Kaganski 2016/12/1 17:54:00, frapuano 2016/12/1 18:28:00, bdrunagle 2016/12/1 19:36:00, Davide Carpi 2016/12/1 19:51:00, Вячеслав Мезенцев 2016/12/2 01:28:00, Radovan Omorjan 2016/12/2 03:13:00, sergio 2016/12/2 07:23:00, NDTM Amarasekera 2016/12/2 08:34:00, Serg 2016/12/3 09:19:00, Arie 2016/12/5 12:13:00, Василий Николаевич Храмушин 2016/12/6 07:13:00, zoom 2016/12/18 23:37:00
#2 已发布: 2016/12/13 14:32:27
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
As always, thank you and the team for the new stable release.
As the work progresses to 0.99 releases, would it be possible to
1) Allow English (IP units) as the default for those of us in the US?
2) Consider making some of the plugins an integral part of the software? (e.g. hyperlink, run, writer region, etc. plugins)
Everyone has an opinion as to "what" should be baked in, so this is programmers choice. My request is for some of the "visuals" to creating a report to be part of the base package.
Thank you
#3 已发布: 2016/12/13 18:59:42
983个赞,共6,866个帖子。
Writer region & hyperlink are all explained in their
respective release. What do you mean "run" ?
F9 calculates the all work sheet.
#4 已发布: 2016/12/20 12:45:08
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
Jean,
My request is for some of the "visuals" to creating a report to be part of the base package/install. Commands such as PDF Files Plugin, Matlab Math Library, Maple Wrapper, SQL, etc. can continue to be brought in on user's wants'/needs.
As an example, I would love to see the "Writer Region" plugin functionality be part of the base install.
This program is Awesome!!! Thanks to all of the time and effort that all of the programmers put in to make such wonderfully functional software as well as all of the bloggers from around the world ...
Happy Holidays!
#5 已发布: 2016/12/21 22:25:34
983个赞,共6,866个帖子。
1. Matlab: functions are in fx menu "mwXXX"
2. Maple: are user command "maple(_"_)
3.PDF: two ways =>
3.a/ Download free PDF from the web, install, print as PDF [give name].
3.b/ Purchase a more advanceed PDF [typical DocuDesk was $50]
4. SQL [Data Base Management]: Smath is essentially an Engineering Document Creator.
5. Viewer: Not part of the standard 6179 package. What should it do ?
#6 已发布: 2016/12/23 13:13:05
983个赞,共6,866个帖子。
Thanks for the viewer demo. As it looks it captures a live web page and more.
From the page where you have installed Smath 6179:
1. Click on plugin(68)
2. Browse for "Viewer" or else plugin
3. Click to download the plugin of interest [zip]
4. Unzip at the Smath destination
5. Now, "Viewer" is in the "Insert menu'
#7 已发布: 2017/1/2 13:43:25
1,362个赞,共2,276个帖子。
I uploaded an interactive (german) tutorial "Erste Schritte mit SMath Studio" to my support page. It is a single .sm file with 22 area regions (topics).
https://extmoodle.th-brandenburg.de/course/view.php?id=34
This perhaps could be distributed easily via the online gallery but I am not sure as what type of extension I should register the file.
- handbooks would require pdf or cbm format
- interactive books would be opened in the limited viewer window (the user of the tutorial is expected to perform exercises)
- example would work but is not really the right word for the stuff.
My recommendation would be to extend the handbooks type to accept self-contained (with no dependencies) .sm files.
PS: I failed to add the tutorial to the wiki list. There was an error when producing the preview.
2位用户喜欢此帖子
Andrey Ivashov 2017/1/9 13:25:00, Davide Carpi 2017/1/13 10:05:00
#8 已发布: 2017/1/22 21:21:34
1,362个赞,共2,276个帖子。
The interactive tutorial has been extended with an english version. You can download it in the extension manager.
7位用户喜欢此帖子
Radovan Omorjan 2017/1/23 04:20:00, frapuano 2017/1/23 04:27:00, sergio 2017/1/23 05:36:00, Davide Carpi 2017/1/23 09:47:00, Serg 2017/1/23 14:01:00, Andrey Ivashov 2017/1/26 18:32:00, Вячеслав Мезенцев 2017/3/6 04:44:00
#9 已发布: 2017/6/29 10:49:00
mikejonson750
mikejonson750
0个赞,共1个帖子。
thank you a lot for this
Divide et impera )))
#10 已发布: 2017/7/8 10:51:07
1,362个赞,共2,276个帖子。
German handbook (316 pages, PDF) updated.
It is based on the pre-configured portable distribution with Maxima, which you can download at TH Brandenburg (Registation required). The file is too large for the extension portal, therefore I distribute it via the external Moodle system of our university.
The distribution comes with a pre-installed interactive handbook (german/english), access it using the help button [?] in the toolbar.
There is also an interactive introduction (tutorial)
2位用户喜欢此帖子
Davide Carpi 2017/7/8 13:47:00, Andrey Ivashov 2017/7/8 19:27:00
