SMath Studio gives wrong result for this integral; BUG in SMath
SMath Studio gives wrong result for this integral; BUG in SMath - Numeric integration, Symbolic calculation - 消息
#1 已发布: 2024/10/14 18:21:07
Cornel
Cornel
2个赞,共78个帖子。
Why SMath studio does not give at least the correct result which is 0.263 for this integral?
Mathcad Prime 10:
-1.849 result is comming from symbolic result calculation, which is wrong in this case, but numeric result 0.263 is correct here also in mathcad prime 10.
Mathcad Prime 6:
SMath Studio:
Wolfram mathematica:
#2 已发布: 2024/10/14 18:24:40
Cornel
Cornel
2个赞,共78个帖子。
Will be good if somebody can announce the owner of SMath Studio...
#3 已发布: 2024/10/14 18:44:24
1,558个赞,共1,868个帖子。
You must clear previous results (implicit definitions). If you do not, the task statement may change. To be sure, do each check separately in a new document.
maple-int-arcsin.sm (7.66 KiB)已下载 1766 次。
#4 已发布: 2024/10/14 18:47:14
600个赞,共1,381个帖子。
It gives correct results, even with embedded or maple.
You need to change arcsin() function to asin() however.
#5 已发布: 2024/10/14 19:15:59
Cornel
Cornel
2个赞,共78个帖子。
Could you post also the worksheet? As I do not know why my function arcsin(x) definition is not taken into account
#6 已发布: 2024/10/14 19:22:09
1,558个赞,共1,868个帖子。
There may be different regional settings here. What you see as a plugin error is not always a plugin error. It may be an error in interpreting the results from the plugin or an error in the program itself. A little investigation is needed to clarify the details of the crime.
#7 已发布: 2024/10/14 20:32:24
600个赞,共1,381个帖子。
Here it is, regards
int-embedded_maple.sm (6.97 KiB)已下载 1746 次。
churichuro 2024/10/14 21:44:00
#8 已发布: 2024/10/14 23:46:58
Stuart Bruff Y
Stuart Bruff Y
0个赞,共4个帖子。
I tried to run this worksheet, and was asked to install Maple Tools. I tried to do this twice and both times, SMath crashed during the install - just vanished into the thin electron cloud, without so much as a goodbye or reason for leaving.
This is on a fresh install of SMath on a new Windows 11 PC that has never had SMath installed before.
#9 已发布: 2024/10/15 00:17:05
600个赞,共1,381个帖子。
I believe there is a problem with smath servers.
It gives the error if you try to install plugin.
Please be patient, it will be fixed soon I guess.
#10 已发布: 2024/10/15 00:30:55
Stuart Bruff Y
Stuart Bruff Y
0个赞,共4个帖子。
OK, that sounds feasible. I did have some trouble downloading SMath, with multiple requests to retry the download.
It would be nice if SMath handled the installation failure with an error message rather than just disappearing.
#11 已发布: 2024/10/15 13:58:25
Cornel
Cornel
2个赞,共78个帖子。
Yes, so it seems to me that SMath has stability problems. By now SMath can give you the answer/correct answer, and after few moments later it can give you incorect answer or SMath to not work properly. Strange things happen with SMath from what I see so far regarding the stability of functionalities or how stable is smath...If today I reach the correct answer, and tomorrow I need to show to other people the results I obtained and then I found that tomorrow SMath did not want to calculate the answer from previos day or to show the answer which I reached a previous day ago, I will be in an embarrassing situation in front of other people
#12 已发布: 2024/10/15 14:05:02
Cornel
Cornel
2个赞,共78个帖子。
I see also the difference between Maxima engine and maple version 6 engine (in symbolic answer). With maxima engine the result is more a rational approximation of an irrational result. I would expected something similar as maple engine give when evaluating integral symbolically.
#13 已发布: 2024/10/15 16:00:37
1,362个赞,共2,276个帖子。
Maxima can't handle the integral. It returns a slightly modified symbolic representation. This is hidden by SMath postprocessing of the symbolic results (which doesn't seem to be suppressed for Optimization> None.
There seems to be a problem in preprocessing/translation when using the Int() function.
Worksheet20.sm (7.27 KiB)已下载 1700 次。
#14 已发布: 2024/10/15 18:58:07
600个赞,共1,381个帖子。
There is a load("abs_integrate)$ statement for these kind of situations.
If not used, maxima can't parse absolute integrals as I have understood.
https://maxima.sourceforge.io/docs/manual/de/maxima_181.html
It doesn't work on my linux commandline maxima however.
Possibly missing the module.
