Equation number in a
Equation number in a - 消息
#1 已发布: 2017/11/4 17:04:03
Paulius
Paulius
0个赞,共11个帖子。
Then writing master thesis I need numbering equation there's a methods to put number on equation, or simple I need put the text near formulas. Example:
3+4=8 (101)
2+3=5 (102)
#2 已发布: 2017/11/5 06:43:35
1,443个赞,共2,936个帖子。
Hello [userlink]Paulius[/userlink],
You can start writing a text region simply by typing the double quotes character (") anywhere in the canvas
You can even use the description area (right click on the math region -> show description) and move it to the side you want dragging his left edge.
#3 已发布: 2017/11/5 07:17:33
983个赞,共6,866个帖子。
Equation [1], [2] are one line, they lineup nicely.
For equation of num/den style: use a construction line
that you will delete after construction.
#4 已发布: 2017/11/5 07:46:56
983个赞,共6,866个帖子。
You can highlight a graph or any math region simply:
1. capture the graph frame using "WinGrab" [freeware]
2. crop the Wingrab selected region
3. copy/paste in IrfanView, inverse colors
Inst_Mach Number Pitot [PUBLISH].sm (30.78 KiB)已下载 1072 次。
