Difference in plotting
Difference in plotting - One case requires x as independent vatiable the other accepts t. - Messages
#1 Posted: 2012/9/20 19:18:21
Basile
Basile
8 likes in 172 posts.
Does anybody knows why this difference in the independent variable?
Thank you,
Basile
#2 Posted: 2012/9/20 20:23:37
1,441 likes in 2,932 posts.
Thank you,
Basile
Hi Basile,
I'm not sure but I think it's something related to "local" and "global" variables... using the line() [MATH]t[/MATH] becomes a local variable for [MATH]i(t)[/MATH], and the "global" [MATH]t:x[/MATH] doesn't affect the function, vice versa without the line() [MATH]t[/MATH] is a global variable for q(t) so plotting the graph you implicitly write "plot q(x)".
regards,
w3b5urf3r
#3 Posted: 2012/9/21 08:54:32
Oscar Campo
Oscar Campo
135 likes in 309 posts.
Hi Basile.
By default x is a global variable in SMath. When you define i(t), t is a local variable.
So, while you try plotting i(t) you get an error because t is not defined. When you define t=x, you obtain plots for i(t) and q(t)
Oscar
#4 Posted: 2012/9/21 09:40:06
Basile
Basile
I can plot q(t) but not i(t) although I defined t:=x.
Can the definition of the functions have anything to do with that, one uses the if statement the other is as usually.
Basile
#5 Posted: 2012/9/21 11:49:29
Basile
You're right, the issue is in the if statement (see the attachments)
to bypass the issue use this workaround:
[MATH]i(t)t>0)*(4*sin(5*t))[/MATH]
regards,
w3b5urf3r
test.sm (8.3 KiB) downloaded 1156 time(s).
