Fractal Tree
Fractal Tree - a programme for displaying a fractal tree - 消息
#1 已发布: 2020/3/15 14:48:37
Gerard Bush
Gerard Bush
8个赞,共9个帖子。
I have created a programme to display a fractal tree in a 2D plot.
fractal tree.sm (7.93 KiB)已下载 1409 次。
fractal tree.pdf (209.83 KiB)已下载 869 次。
I would be interested to find out if there is a way to animate the plot process so that the fractal tree is drawn element by element, as each point is calculated.
Can anyone give me any pointers on how to do it?
If that is not possible, how would the animation be done after all the plot points are calculated?
Thank you
Gerard Bush
Davide Carpi 2020/3/16 12:19:00
#2 已发布: 2020/3/15 18:30:25
983个赞,共6,866个帖子。
Like this ... in ½ points.
fractal tree.sm (11.31 KiB)已下载 1398 次。
#3 已发布: 2020/3/16 07:13:02
983个赞,共6,866个帖子。
... hard to size the animation plot canvas.
Otherwise renders well ½ length ... greedy 1533 frames !
Search "Samples"... "Pattern" for lot more.
If you can't find and want more: please ask for.
Pattern fractal tree.sm (17.6 KiB)已下载 1333 次。
2位用户喜欢此帖子
Gerard Bush 2020/3/16 08:25:00, Davide Carpi 2020/3/16 12:19:00
#4 已发布: 2020/3/16 08:16:56
Gerard Bush
Gerard Bush
8个赞,共9个帖子。
Thank you Jean,
That is just what I was looking for.
To reduce the number of points, and reduce the calculation time the minimum length can be increased. For example, change 'if lenght > 0.25' in the tree function to 'if length > 1.0'. I guess this could even be defined as a variable.
Cheers,
Gerard
Pattern fractal tree.sm (18.39 KiB)已下载 1334 次。
#5 已发布: 2020/3/16 09:04:22
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
In the program Jean I added the growth of the tree
Pattern fractal 1.sm (12.54 KiB)已下载 1344 次。
5位用户喜欢此帖子
Davide Carpi 2020/3/16 12:19:00, Alvaro 2020/3/17 16:15:00, Вячеслав Мезенцев 2020/3/16 13:59:00, frapuano 2020/3/16 09:35:00, Gerard Bush 2020/3/16 10:55:00
#6 已发布: 2020/3/16 17:55:35
983个赞,共6,866个帖子。
Few more attached ... Search Julia, Mandelbrot in Forum.
Pattern Koch.sm (11.2 KiB)已下载 1351 次。
Pattern Frieze Heppi.sm (11.97 KiB)已下载 1371 次。
Pattern Hilbert.sm (8.53 KiB)已下载 1325 次。
Pattern Patch Work.sm (10.92 KiB)已下载 1361 次。
Pattern Fractal Sierpinski.sm (10.92 KiB)已下载 1387 次。
Pattern Snail.sm (26.85 KiB)已下载 1375 次。
Pattern Fern.sm (19.4 KiB)已下载 1382 次。
Pattern Sierpinski Kover.sm (16.72 KiB)已下载 1365 次。
Pattern Etoile Magic [Short].sm (46.69 KiB)已下载 1155 次。
Pattern Sierpinski Triangles.sm (35.21 KiB)已下载 1341 次。
Pattern Prototile.sm (116.5 KiB)已下载 1424 次。
#7 已发布: 2020/3/16 17:59:14
983个赞,共6,866个帖子。
Pattern PythagorasTree.sm (6.99 KiB)已下载 1389 次。
#8 已发布: 2020/3/17 15:24:27
983个赞,共6,866个帖子。
Hello Gerard ! ... today, I have cut the tree for You.
Pattern fractal tree [CUT].sm (11.03 KiB)已下载 1143 次。
Gerard Bush 2020/3/18 09:56:00
#9 已发布: 2020/3/18 09:58:54
Gerard Bush
Gerard Bush
8个赞,共9个帖子。
Thank you very much, Jean and Ber7 for your additions!
#10 已发布: 2020/3/18 12:06:31
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Fractal tree with leaves
Pattern fractal 3.sm (12.01 KiB)已下载 1349 次。
3位用户喜欢此帖子
Davide Carpi 2020/3/18 15:07:00, Gerard Bush 2020/3/18 16:59:00, NDTM Amarasekera 2020/3/19 06:03:00
