Weird Unit Conversion kg <> ton
Weird Unit Conversion kg <> ton - 消息
#1 已发布: 2018/5/14 05:27:41
usamakhan
usamakhan
7个赞,共98个帖子。
The question is simply clear ...its should be a matter of removing or adding x3 zeros
aMIR.sm (10.5 KiB)已下载 1171 次。
#2 已发布: 2018/5/14 05:36:20
1,443个赞,共2,936个帖子。
Simple as the question
#3 已发布: 2018/5/14 06:00:37
usamakhan
usamakhan
7个赞,共98个帖子。
Thanks ...but can you tell me what is the wrong in this kg <> ton ...it should just reduce the power to 10 from 8 to 3 without changing the values
#4 已发布: 2018/5/14 06:04:53
1,443个赞,共2,936个帖子。
I missed it...
You have to use 't (metric ton) because 'ton here is the US "short ton"
#5 已发布: 2018/5/14 06:10:11
usamakhan
usamakhan
7个赞,共98个帖子。
I think its the problem ...I was expecting MetricTons
Problem solved
