question about 2D graph
question about 2D graph - Messages
#1 Posted: 2020/6/14 14:46:33
churichuro
churichuro
29 likes in 79 posts.
hello again.
How can I get a graph from a variable? Example in graph 2 where nothing appears.
the content of the variable is pasted directly into graph 1 and
there it is working
I generate the matrices to draw a series of rectangles
but I don't know in advance how many rectangles will be drawn
that's why I require to use a variable that contains a system of several matrices
is there another solution?
stack-of-rec.sm (29.67 KiB) downloaded 945 time(s).
#2 Posted: 2020/6/14 18:04:22
1,353 likes in 2,264 posts.
There might be other issues, but one of them could be the bug demonstrated here. Normally, no element assignment should alter the object type from list to matrix as it seems to happen in the line block definition. I think this is another regression, such stuff used to work in older versions (here 7251).
The original desparate workaround with str2num tries to handle the bug. Normally you should be able to reliably initialize a variable using any object of appropriate type.
Lists.sm (7.5 KiB) downloaded 938 time(s).
#3 Posted: 2020/6/14 19:48:13
Transit the 'gg' matrices via file, plot.
stack-of-rec.sm (31.93 KiB) downloaded 940 time(s).
#4 Posted: 2020/6/14 20:56:33
churichuro
churichuro
thank you very much Martin Kraska and also to you Jean Giraud
both options work well
I attach the file with Martin's suggestion, which I
It seems what I was looking for, and I take note of the solution
Jean who as always is very helpful and educational
since you learn a lot from these examples.
Thank you!
stack-of-rec.sm (23.12 KiB) downloaded 918 time(s).
#5 Posted: 2020/6/14 21:04:19
Much simpler Amigo ...
Isolate 'gg' gg:= gg ...or rectangles:= gg
#6 Posted: 2020/6/14 21:44:58
churichuro
churichuro
Hahaha yes! this work too.
#7 Posted: 2020/6/15 11:39:52
If you want unicolor plot and rotation,
you may have to reconsider your construction.
Utilities XY [Draw Truss].sm (22.85 KiB) downloaded 783 time(s).
stack-of-rec.sm (37.11 KiB) downloaded 935 time(s).
churichuro 2021/5/12 13:36:00
#8 Posted: 2020/6/15 13:55:02
Your H beam, you can have it SVG style.
Spline De Casteljau SVG Hbeam.sm (41.36 KiB) downloaded 1016 time(s).
#9 Posted: 2020/6/15 14:26:17
The issue demonstrated in the above post nails down to unexpected handling of single element lists used to initialize the data under numeric optimization.
lists2.sm (6.44 KiB) downloaded 919 time(s).
Davide Carpi 2020/6/15 15:08:00, frapuano 2020/6/16 02:45:00
