Ode solvers implementation
Ode solvers implementation - 消息
#1 已发布: 2018/11/29 19:09:04
1,139个赞,共1,805个帖子。
Hi. I can't reproduce this in SMath.
未找到文件。未找到文件。
2位用户喜欢此帖子
Вячеслав Мезенцев 2018/11/30 03:25:00, Radovan Omorjan 2018/11/30 05:06:00
#2 已发布: 2018/11/29 23:48:00
983个赞,共6,866个帖子。
1/1 in Smath 6179, proof: the snippet.
Cheers Alvaro
Integrate with ode solver.sm (29.07 KiB)已下载 1329 次。
#3 已发布: 2018/11/29 23:59:54
983个赞,共6,866个帖子。
You may not be able to implement the Mathcad bloc Given/ODEsolve.
ODEsolve is based on linterp. That is the first point.
The other point is that in Mathcad "linterp(x)" is a scalar function.
In Smath: ainterp, cinterp, linterp are simply interpolation fncts
They are not scalar functions. How does it reflects in ODEsolve ?
In Smath, ln(x), exp(x), ... are scalar from source code.
I tried to make cinterp scalar like in Mathcad, not to avail.
Please, persist on such a beautiful idea.
#4 已发布: 2018/11/30 01:16:48
983个赞,共6,866个帖子。
This document was essentially designed to plot scalar the derivative on canvas,
as well as get a discrete export. Also included: the scalar quadratic.
Spline Deriv Infinitesimal.sm (70.87 KiB)已下载 1347 次。
#5 已发布: 2018/11/30 02:31:22
1,139个赞,共1,805个帖子。
Hi Jean. Actually not, just the solver, without the given.
I found how to call the odesolver, with D(x,y)=[f(x)].
This method is much more faster than the direct integration.
But remains the ln(0) error, which seems to be a bug in the odesolvers, because zero isn't in the domain range.
Integrate with ode solver.sm (10.17 KiB)已下载 1274 次。
Radovan Omorjan 2018/11/30 05:10:00
#6 已发布: 2018/11/30 03:35:52
1,558个赞,共1,868个帖子。
The zero point is used to determine the dimension of the vector D(t,x) at runtime (D(0, x0)). The size of the system must be determined for the further operation of the numerical algorithm. It seems that it would be correct to substitute the beginning of the interval. I will try to change this. Also, if possible, I will support the one-dimensional case.
4位用户喜欢此帖子
sergio 2018/11/30 05:43:00, frapuano 2018/11/30 05:37:00, Alvaro 2018/11/30 04:53:00, Radovan Omorjan 2018/11/30 05:06:00
#7 已发布: 2018/11/30 05:01:06
1,139个赞,共1,805个帖子。
Thanks Viacheslav. It's amazing the effort that you and the others plugins developers put in enhance SMath, with very spectacular results.
#8 已发布: 2018/11/30 12:29:42
983个赞,共6,866个帖子。
Buenos dias Alvaro !
ln(0) was introduced in Mathcad 11 soon after release via update [from recollection]
There is more in the attached, specially wrt parametric D(,,,).
ODE 0_Model General.sm (29.47 KiB)已下载 1310 次。
#9 已发布: 2018/11/30 12:34:54
983个赞,共6,866个帖子。
#10 已发布: 2018/11/30 15:36:38
983个赞,共6,866个帖子。
... refreshed version wrt explore all solvers.
ODE 0_Model General.sm (38.44 KiB)已下载 1265 次。
3位用户喜欢此帖子
Alvaro 2018/11/30 15:54:00, frapuano 2018/11/30 17:58:00, Davide Carpi 2018/12/3 21:18:00
