Is there an easy way or built in way to insert values into a matrix?
For example if I have a 2x4 matrix and I want to insert a column. How can this be done?
Is it possible to sort a matrix so that the columns are rearranged until the specified row is in ascending order?
If not is there a way to invert a 2x4 matrix so that the row is now the column. See attached example.
Thanks
Matrix Manipulations.sm (6.61 KiB)已下载 1183 次。
