Segment by segment multiplication of ranges
Segment by segment multiplication of ranges - 消息
#1 已发布: 2019/2/10 07:22:24
StoyanovR
StoyanovR
0个赞,共3个帖子。
Is there a more convenient way of segment by segment multiplication of ranges than using a for cycle.
I am trying to solve the following:
(the problem is that all the data in the range should be segment by segment squared)
and also
Currently I have been able to solve the examples using a 'for' cycle:
But my question is: Is there a more convenient way to multiply, divide, square and root ranges segment by segment?
Thanks in advance!
Best regards,
Radko
#2 已发布: 2019/2/10 08:50:01
325个赞和1个踩,共2,052个帖子。
Use vectorize from Matrix palette.
Andrey Ivashov 2019/2/14 18:49:00
#3 已发布: 2019/2/10 08:56:02
StoyanovR
StoyanovR
0个赞,共3个帖子。
Thank you Radovan!
It saves a lot of time!
Have a nice day!
Radko
#4 已发布: 2019/2/10 11:33:25
983个赞,共6,866个帖子。
#5 已发布: 2019/2/10 11:40:48
StoyanovR
StoyanovR
0个赞,共3个帖子。
Thank you Jean!
