SMath论坛 SMath Studio Bugs & Problems Wrong result when using function SUM() 1页(3条) Wrong result when using function SUM() - SUM() bug - 消息 转到最后一个帖子 #1 已发布: 2015/6/12 11:58:36 shelley 0个赞,共15个帖子。 组: User Could anyone look at this problem? The summation could not recognize the negative sign.Please see the attached. Marked with yellow is not right. #2 已发布: 2015/6/12 17:10:52 Radovan Omorjan 325个赞和1个踩,共2,052个帖子。 组: Moderator Hello,This is again one of the weird SMath behavior regarding optimization.Just right click on at least a:=-h region and turn on Numeric optimizationRegards,Radovan When Sisyphus climbed to the top of a hill, they said: "Wrong boulder!" 2位用户喜欢此帖子Davide Carpi 2015/6/12 18:04:00, ioan92 2015/6/13 06:49:00 #3 已发布: 2015/6/18 16:35:11 shelley 0个赞,共15个帖子。 组: User WroteHello,This is again one of the weird SMath behavior regarding optimization.Just right click on at least a:=-h region and turn on Numeric optimizationRegards,RadovanThank you. It works turning on numeric 1页(3条) 有新帖 无新帖
