CTRL+drag and CustomRegions
CTRL+drag and CustomRegions - 消息
#1 已发布: 2013/8/1 09:48:30
1,443个赞,共2,936个帖子。
Some issues when copying CustomRegions (like built-in 2D plots) with CTRL+drag:
- when the description is enabled cause an oversized selection of the output; if the base region have a description and is disabled, some glitches appears
- if you select the original region and you change the font size, the clone have the same font-size of the original (CTRL+V display the output with the correct font-size)
best regards,
Davide
MOVED IN THE BUG TRACKER
#2 已发布: 2013/8/1 19:09:40
2,344个赞,共4,057个帖子。
组: Super Administrator
Thank you! I'll check it.
