solver, function with "for loop" not working
solver, function with "for loop" not working - solver error - 消息
#1 已发布: 2021/1/24 23:37:07
rodp1
rodp1
0个赞,共8个帖子。
Hi all, trying to get "solve" to work with a function that has a "for loop"
The crux of the issue is this part. Is what I'm doing just not possible?
File attached
upload-question1.sm (18.19 KiB)已下载 1134 次。
#2 已发布: 2021/1/25 09:04:36
983个赞,共6,866个帖子。
Plot that function first, then solve.
That will clarify the suite.
upload-question1 Solve.sm (22.01 KiB)已下载 1142 次。
#3 已发布: 2021/1/25 09:34:52
983个赞,共6,866个帖子。
No problem from correctly dressed system.
#4 已发布: 2021/1/26 22:03:54
rodp1
rodp1
0个赞,共8个帖子。
Thanks for the attempt to help Jean, but I surmise from your answer that the particular construct I'm using, which involves a "sign" function, can't be solved using the "solve" function.
As shown in the attachment, the function does have a root.
#5 已发布: 2021/1/26 23:39:52
983个赞,共6,866个帖子。
I was suggesting a solve bloc within a for loop, your original question.
#6 已发布: 2021/1/27 04:33:04
1,139个赞,共1,805个帖子。
Sign isn't one of the problematic functions for solve (maybe for diff or int, but not for solve). Here is the problem: Mathcad have an special notation for the imaginary unit as 1i or 1j, SMath doesn't. Just change "i" by "n" under your Sigma:
#7 已发布: 2021/1/27 05:40:26
rodp1
rodp1
0个赞,共8个帖子。
Raznor - thanks for that! Appreciated.
I managed to solve it a slightly different way - rather than using the explicit summation form, I replaced it with a sum() call. So I didn't need to explicitly define the counter.
I have to stop trying to program like it's VBA
