Graphing a function, but I cannot adjust the axes limits
Graphing a function, but I cannot adjust the axes limits - Title. - 消息
#1 已发布: 2024/8/1 11:49:35
ALLAN PAOLO LABARTINOS ALMAJOSE
0个赞,共1个帖子。
I am completely aware that the documentation said that you cannot adjust the axes limits when using vanilla plot function. Is there a plugin that is able to resolve this issue?
Or rephrasing; is there an available plugin that allows users to plot functions and adjust the axes limits of the plot?
TYIA.
#2 已发布: 2024/8/1 18:38:01
600个赞,共1,381个帖子。
You can use XYPlot and setprop() function for that purpose.
Here is sample file for setprop function.
setprop.sm (21.36 KiB)已下载 1662 次。
ioan92 2024/8/2 14:33:00
#3 已发布: 2024/8/7 22:03:13
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings,
As a note: the 'name' of the graph (in this case XYPlot1 and XYPlot2) is specified via the XY-Plot Properties (i.e., double-click the graph to see the full list of properties); one of those fields is called "Name" which would be the title to reference the Plot through the 'setprop()' command.
May this be of Good Help;
