plotting circle does not work
plotting circle does not work - Help - 消息
#1 已发布: 2022/3/13 10:52:33
Blackbambi
Blackbambi
0个赞,共3个帖子。
I am trying to plot mohr's circle by following tutorial. I have succeeded to draw circle on the tutorial but not mine.
Could you check my plot?
Thank you.MSS_Failure criterion.sm (8.47 KiB)已下载 1323 次。
#2 已发布: 2022/3/13 11:47:06
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
One way to build a graph is to lower the order of large numbers
Primer.sm (8.51 KiB)已下载 1255 次。
#3 已发布: 2022/3/13 12:32:01
600个赞,共1,381个帖子。
You can make a function to draw circles, for multiple usage on same sheet.
With respect to Ber7, dividing it to MPa will lower the numbers too.
MSS.sm (7.3 KiB)已下载 1298 次。
#4 已发布: 2022/3/13 22:37:25
Blackbambi
Blackbambi
0个赞,共3个帖子。
Thank you all. I appreciate your help
#5 已发布: 2022/3/14 13:06:17
1,362个赞,共2,276个帖子。
Here is a version with pre-defined geometric object in the XY plot plugin. See Handbuch section 8.3.4.
MSS_Kr.sm (13.86 KiB)已下载 1307 次。
#6 已发布: 2022/3/14 14:11:02
983个赞,共6,866个帖子。
Circle de Mohr.sm (47.02 KiB)已下载 1300 次。
#7 已发布: 2022/3/15 04:28:27
Blackbambi
Blackbambi
0个赞,共3个帖子。
Thank you for sharing your work
#8 已发布: 2022/3/15 09:42:51
983个赞,共6,866个帖子。
There are many ways to plot circles wrt applications.
My most used brew ... Cheers, Jean.
Page4 Circles_Ellipses.sm (9.36 KiB)已下载 1457 次。
#9 已发布: 2022/3/15 13:22:17
600个赞,共1,381个帖子。
It is much easier to draw circles with X-Y Plot plugin.
circle_xy.sm (5.23 KiB)已下载 1364 次。
#10 已发布: 2022/3/20 15:38:42
983个赞,共6,866个帖子。
My most used brew
I prefer incremental discretizer.
Circle [QUICK,oblate_prolate].sm (14.23 KiB)已下载 1099 次。
