Plot - axis scale
Plot - axis scale - 消息
#1 已发布: 2014/11/30 12:05:42
Kamil
Kamil
0个赞,共3个帖子。
I can't change the axis scale, using wheel or touchpad. When I move up or down, numbers on an axis grows. I can't "zoom out". Is the any other way to change the scale? Using keyboard for example
#2 已发布: 2014/12/2 06:14:48
1,443个赞,共2,936个帖子。
Use SHIFT+mouseWheel or CTRL+mouseWheel to change the scale of a single axis (x and y, respectively).
If you want a precise scaling, use a plugin (like X-Y Plot Region)
Or you have experienced a bug?
