I would like to plot this function
I would like to plot this function - Computing the length of a reflected path. - 消息
#1 已发布: 2019/10/13 17:18:05
Harry Mangurian
Harry Mangurian
0个赞,共3个帖子。
I have attached aReflection.sm (50.87 KiB)已下载 1154 次。 .sm file containing a computation I would very much like to plot.
The geometry is shown in the picture below.
Can someone help ?
Thanks,
problem geometry
#2 已发布: 2019/10/13 18:23:01
983个赞,共6,866个帖子。
Oh ! ... your proposal is not much productive, is it ?
The picture is strictly discontinuous.
Reflection.sm (54.37 KiB)已下载 1177 次。
#3 已发布: 2019/10/13 18:28:17
983个赞,共6,866个帖子。
#4 已发布: 2019/10/13 18:33:49
Harry Mangurian
Harry Mangurian
0个赞,共3个帖子。
I don't think L is discontinuous for ddegrees in the range 0 to 60.
What am I missing here ?
L(ddegrees) should vary smoothly from L(0) to L(60)
#5 已发布: 2019/10/13 23:00:11
983个赞,共6,866个帖子。
You are missing to plot the literal demo diagram,
here is as per your inputs [a,b,s,t].
More is missing from incomplete project description.
Reflection [abst].sm (62.14 KiB)已下载 932 次。
#6 已发布: 2019/10/14 11:27:00
983个赞,共6,866个帖子。
Refreshed from your literal inputs.
You may have to revisit your College Physics book.
Cheers ... Don't hesitate.
Reflection [abst].sm (128.95 KiB)已下载 911 次。
#7 已发布: 2019/10/14 11:46:04
Arie
Arie
94个赞,共285个帖子。
Yes the length L is continuous with respect to ddegrees. I think Jean misunderstands the question. See attached. (A little sloppy but it works)
Edit: Updated graph to add labels
Edit2: Had an error in definition of L. Fixed.
Reflection_alyles.sm (177.77 KiB)已下载 1197 次。
#8 已发布: 2019/10/14 13:45:09
983个赞,共6,866个帖子。
Quite right: misunderstood the travelling distance vs °incidence.
Thanks, interesting project. We need more real projects.
Reflection [abst, alyles].sm (186.64 KiB)已下载 975 次。
#9 已发布: 2019/10/14 15:31:04
983个赞,共6,866个帖子。
... You can have it to a good degree of accuracy
as a continuous function, though a bit strange.
Reflection [abst, alyles].sm (252.97 KiB)已下载 957 次。
#10 已发布: 2019/10/14 16:00:54
Arie
Arie
94个赞,共285个帖子。
FYI Jean you're using one of my earlier files where I had a copy paste error in the derivation of L(d), the second root term should only have s*tan(d*pi/180). You can get rid of the "c-"
#11 已发布: 2019/10/14 17:47:14
983个赞,共6,866个帖子。
Thanks ... updated.
The model fit is brute force, limited.
From my 100's models, not one immediate.
If interested: let me know, not sure if possible.
Reflection [abst, alyles].sm (209.76 KiB)已下载 961 次。
#12 已发布: 2019/10/14 20:55:19
983个赞,共6,866个帖子。
I understand the idea to tabulate as demanded,
in fact useless as you have the continuous function.
Purely Edu. LinfitCheby added.
No problem to export as a function.
Thanks alyles for completing the project.
Reflection [abst, alyles].sm (232.29 KiB)已下载 964 次。
