Vector element operations
Vector element operations - 消息
#1 已发布: 2014/6/6 19:33:19
Cyborgtable
Cyborgtable
0个赞,共1个帖子。
I've just recently discovered this software and have probably is a simple question but I can't find the answer to it.
I'm trying to square each element in a vector and can't find a way to do it.
#2 已发布: 2014/6/7 02:42:55
325个赞和1个踩,共2,052个帖子。
Look at this or this or this posts. To make long story short, in SMath you should use loops for that, or to use Maxima plugin, or to use something like this.
[MATH=eng]v:mat(4,5,1,2,3,4,6,1)[/MATH]
[MATH=eng]sys2mat(mat2sys(v)^2)=mat(16,25,1,4,9,16,6,1)[/MATH]
This is many time mentioned problem from beginners
#3 已发布: 2025/5/10 15:36:17
RegRetired
RegRetired
8个赞,共144个帖子。
Your hotlinks do not work. Please provide correct links.
Thanks,
Reg
Reg CurryLoveland, CO
#4 已发布: 2025/5/11 10:44:58
1,362个赞,共2,276个帖子。
