Newbie problem - Using a range of angles inside a cosine function
Newbie problem - Using a range of angles inside a cosine function - Trying to use cos(variable angle) - 消息
#1 已发布: 2012/10/3 06:41:00
jjuddgb
jjuddgb
0个赞,共2个帖子。
I'm trying to convert some old Mathcad files into SMath but am stuck with what must be an elementary problem, I've looked at various tutorials but can't find a solution, no doubt due to my own incompetence.
I am defining the following variables: angle:=72 and varangle:= 0, angle/2..360
In Mathcad if I then define: test(varangle):= cos(varangle) the output of test(varangle) displays correctly in a column.
If I try the same in SMath I receive either an 'argument must be scalar' or 'fill in all empty elements' error.
Thanks for any advice.
Screenshots of Mathcad and SMath attached.
btw, great software.
Mathcad - output.pdf (26.44 KiB)已下载 1008 次。
#2 已发布: 2012/10/3 07:49:27
kilele
kilele
134个赞,共397个帖子。
Correct me if i'm wrong, trigonometric functions don't support arrays currently.
For now, you can do something like this.
cosinOfArray.sm (5.04 KiB)已下载 1896 次。
1752 2024/9/28 14:44:00
#3 已发布: 2012/10/3 11:09:17
jjuddgb
jjuddgb
0个赞,共2个帖子。
Thank you kilele
#4 已发布: 2012/10/3 11:31:19
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
You can convert the vector into a system (by w3b5urf3r_reloaded)
Regards, Ber7
https://smath.com/wiki/GetFile.aspx?File=cosinOfArray%5b1%5d.rar
Davide Carpi 2012/10/3 13:33:00
#5 已发布: 2012/10/3 11:33:28
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Regards, Ber7
#6 已发布: 2024/9/28 14:44:50
1752
1752
0个赞,共3个帖子。
did arrays appear in trigonometric functions?
#7 已发布: 2024/9/28 16:09:41
127个赞,共342个帖子。
now you can use the "vectorize" function, which you also find in the side panel, and perform the trigonometric function element by element.
1752 2024/9/28 16:30:00
#8 已发布: 2024/9/29 22:22:50
1,362个赞,共2,276个帖子。
An alternative to the vectorize() function is the use of index vectors.
They, however, only work if they are used in a definition.
Worksheet1.sm (5.28 KiB)已下载 1658 次。
sergio 2024/9/29 23:37:00
