1页(7条)
Animation Compendium - Animation Compendium - 消息
Animation adds live to projects.
Enjoy your vist.
0Anim Brownian.sm (8.86 KiB)已下载 1566 次。
0Anim Analemma.sm (28.67 KiB)已下载 1450 次。
0Anim Ellipse.sm (13.42 KiB)已下载 1494 次。
0Anim Cheval.sm (21.13 KiB)已下载 1523 次。
0Anim Gozilla.sm (11.26 KiB)已下载 1461 次。
0Anim XFR.sm (11.65 KiB)已下载 1500 次。
Enjoy your vist.
Davide Carpi 2016/8/22 12:05:00
Hi Jean
The program will run faster if the code is a little change
0Anim XFR1.sm (13.23 KiB)已下载 1452 次。
Davide Carpi 2016/8/22 12:04:00
Thanks Ber7 for the code.
On that one "0Anim CONVOLUTION" ... can't accumulate the path ?
Cheers, Jean
0Anim CONVOLUTION.sm (18.42 KiB)已下载 1488 次。
Cheers, Jean
0Anim CONVOLUTION .sm
has been doctored for the accumulated path.
Plots are difficult to size, work sheet is Autocal OFF
0Anim CONVOLUTION.sm (30.72 KiB)已下载 1523 次。
Thank you for interesting examples!
I've checked your worksheets and see one place for simple optimization applicable for most of them.
Often you use procedures to draw static set of points for all frames of animation. Procedures (when line is used right after the definition operator) calculated on every call - SMath Studio do not precalculate their values.
So, you can speed up calculation simply by line like this:
This line asks the program to calculate procedure and store its values into the initial procedure variable. So, we have only one calculation of static shape for the whole animation!
I've corrected your examples according to the hint above and tested them in both versions: 0.97.5346 - the one you have used to create files and 0.98.6077 - the latest nightly build. Here are the results:
Final versions of the worksheets:
- 0Anim Analemma.sm (28.88 KiB)已下载 1473 次。
- 0Anim Brownian.sm (8.86 KiB)已下载 1476 次。
- 0Anim Cheval.sm (22 KiB)已下载 1485 次。
- 0Anim Ellipse.sm (13.85 KiB)已下载 1539 次。
- 0Anim Gozilla.sm (11.71 KiB)已下载 1462 次。
- 0Anim XFR.sm (12.01 KiB)已下载 1454 次。
- 0Anim XFR1.sm (11.53 KiB)已下载 1475 次。
- 0Anim CONVOLUTION.sm (28.13 KiB)已下载 1501 次。
3位用户喜欢此帖子
Thanks Andrey: I toke good note and adapted.
1页(7条)
