Smath Solver
Smath Solver - 消息
#1 已发布: 2022/1/21 06:45:25
Beyaz
Beyaz
0个赞,共19个帖子。
Im trying convert this mathcad solver to smath but it doesnt work.
Radius_318a.sm (9.34 KiB)已下载 1295 次。
#2 已发布: 2022/1/21 11:44:53
127个赞,共342个帖子。
It is a non-linear system. With the internal "Roots" solver it is appropriate to use initial values ​​sufficiently close to the result.
You can use some of the smath plugins that are more robust. For example, with "Solve" of the "Maxima plugin you get the result.
显示剧透
Radius_318a_ser.sm (337.14 KiB)已下载 1375 次。
#3 已发布: 2022/1/21 17:30:18
600个赞,共1,381个帖子。
With an addition to sergio's solution;
You can use vectors while solving.
#4 已发布: 2022/1/21 20:59:15
600个赞,共1,381个帖子。
Solution with another solver.
al_nleqsolve.sm (6.99 KiB)已下载 1264 次。
#5 已发布: 2022/1/26 03:52:33
Beyaz
Beyaz
0个赞,共19个帖子。
wow, thanks a lot guys.
//Edit: the thanks button is not working. I cant give you thanks
