Curve fit function?
Curve fit function? - Looking to do a pump curve fit - 消息
#21 已发布: 2016/4/21 03:48:18
1,362个赞,共2,276个帖子。
Hello Martin,
Very interesting, but does not work in 5346.
Your work sheet does not work either.
I can't reproduce the problem with the unofficial portable distribution.
If you use this from an usb stick, do you get the same problem on different computers?
#22 已发布: 2016/4/21 21:48:49
983个赞,共6,866个帖子。
Originally Posted by: Jean Giraud [url=/forum/yaf_postsm32927_Curve-fit-function.aspx#post32927][/url]Hello Martin,
I will try to isolate the problem. Actually Smth resides in only one of my 5 PC's.
Thank Martin, Jean.
