How to create series / table having variable with power
How to create series / table having variable with power - How to create series / table having variable with power - 消息
#1 已发布: 2016/4/12 15:26:24
Shafiq ur Rehman
Shafiq ur Rehman
0个赞,共4个帖子。
Dear SMATH users
Please help me that how to generate series or table with variable having power.
In Mathcad it is very simple
a simple calcs has been shown belwo with a variable x having power 2. In mathcad it y(x) series can be easily generated, but smath results are not same.
So guide me that how to generate similar calcs in smath.
Shafiq
#2 已发布: 2016/4/12 15:54:20
Ernesto
Ernesto
13个赞,共74个帖子。
You need to use the "vectorize function" over the function to get it to work.
Shafiq ur Rehman 2016/4/13 00:48:00
#3 已发布: 2016/4/12 16:55:02
983个赞,共6,866个帖子。
1. Vectorise is not available in version 5346
2. Vectorise is local. For more genaral use, universal algo style
is a better choice. Plug the module at the top of the work sheet
collapse and have it in hand further down the WS.
Shafiq ur Rehman 2016/4/13 00:49:00
#4 已发布: 2016/4/12 17:51:22
983个赞,共6,866个帖子。
... in the attached, where you have Vectorise(f,zoom), try to write
Z:=f(zoom) under the vectorise operator and see if it works.
But don't zap the existing working Z:=Vectorise(f,zoom).
The grayscale is in the collapsed area, no need to import.
The construction stuff is also collapsed "Fourier"
Forum Fourier Zoom Image.sm (123.11 KiB)已下载 1371 次。
#5 已发布: 2016/4/13 16:14:57
Shafiq ur Rehman
Shafiq ur Rehman
0个赞,共4个帖子。
Thanks Ernesto and Jean Giraud for providing me great help.
Shafiq
