Derivative the 2-d order
Derivative the 2-d order - 消息
#1 已发布: 2023/5/29 03:42:44
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Is there the Derivative the 2-d order in SMath? I see only 1-st order.
Thanks!
#2 已发布: 2023/5/29 07:43:03
1,362个赞,共2,276个帖子。
It is not in the side panel but you can select it in the dynamic assistant or in the Insert functions dialog.
Valery Ochkov 2023/5/29 08:28:00
#3 已发布: 2023/5/29 08:54:18
983个赞,共6,866个帖子。
As well, you can have multiple derivatives.
f(x) is the integrand of erf(x)
Cheers ... Jean.
