1页(3条)
roots() bug with a simple linear system of equations - roots() returns "not real roots" - 消息
Trying to solve a simple linear system of equations (2 equations) using the roots() function gave me the error message "No real roots", but changing the order of the elements of one of the equations, solved it.
I know this is not so important, but it was interesting to see how SMath`s functions behaves.
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University.
2位用户喜欢此帖子
Confirmed,
It seems some bug is here.
FindRoot() from Nonlinear Solvers plugin will work well here
[MATH=eng]FindRoot(mat(A+B-108,2*A-3*B-156,2,1),mat(A≡0,B≡0,2,1))=mat(96,12,2,1)[/MATH]
2位用户喜欢此帖子
Symbolic optimization fails to recognize the difference of the equivalent expresions to zero in one step. If the result is taken and again symbolically optimized, then zero is identified. Perhaps an internal workaround for such problems could be to repeatedly apply symbolic optimization until there are no more changes.
roots.sm (17.08 KiB)已下载 1472 次。
3位用户喜欢此帖子
1页(3条)
