Unable to assign to variable in SS 0.98.5981 when using FindRoot Function
Unable to assign to variable in SS 0.98.5981 when using FindRoot Function - Messages
#1 Posted: 2016/5/18 09:20:15
NDTM Amarasekera
NDTM Amarasekera
130 likes in 352 posts.
Hi
The "Open Channel Design" file attached earlier had erros inside the program section in calculating the critical slopes for each bed width. The corrected program is attached now.
Regret any inconvenience.
Now I observe that the result of FindRoot function unable to assign to a variable in attached SS file.
Test_FindRoot-1.sm (40.22 KiB) downloaded 1046 time(s).
Above file was extracted from the original file Channel Design-using FindRoot-R1.sm (206.01 KiB) downloaded 1062 time(s). for testing, but both had the same problem
under SS 0.98.5981. However, it was perfectly OK when I uploaded on 18th Oct. 2015 (cannot remember the SS version).
As Andrey has suggested, I did a clean installtion of SS, but the problem still exists.
Another isuue is also shown in the image.
#2 Posted: 2016/5/18 10:05:46
Alexander O. Melnik
Alexander O. Melnik
127 likes in 498 posts.
Hi
Your worksheet will work in latest stable release 5935. The error you are facing is likely due http://smath.info/bts/Issues/IssueDetail.aspx?id=2318; I have a worksheet that is broken due to this and Andrey said he will fix it in the next nightly.
Regarding 3m - 2m = m, well I do hope Andrey will fix this - it is clearly an undesired behaviour.
#3 Posted: 2016/5/18 10:07:09
It works, version 5346 UNofficial distribution
#4 Posted: 2016/5/18 11:38:04
NDTM Amarasekera
NDTM Amarasekera
Thanks Alex and Jean for the clarifications. I tried in SS 5935 but not successful.
I hope these issues will be resolved by Andrey at his earliest.
Many thanks to Andrey for your great efforts and contributions in this regard.
#5 Posted: 2016/5/19 19:06:54
2,326 likes in 4,013 posts.
Thank you! I will check this before next stable release.
But for now it can be fixed by plug-ins developer as I've suggested here: http://en.smath.info/forum/yaf_postsm33336_SMath-Studio-0-98-5973--09-May-2016.aspx#post33336
Let me know if any help from my side required.
Regards.
Davide Carpi 2016/5/19 19:52:00
#6 Posted: 2016/5/20 12:09:19
Alexander O. Melnik
Alexander O. Melnik
Hi
A working fix is to use line() in the function definition. Hope this helps Andrey to find a permanent fix.
Test_FindRoot-1.sm (40.68 KiB) downloaded 1037 time(s).
Davide Carpi 2016/5/20 14:05:00
#7 Posted: 2016/5/20 16:46:55
Alexander O. Melnik
Alexander O. Melnik
Well I tried... It is still not possible to assign a value to a variable using FindRoot(). This nightly is officially broken for me - I NEED A WORKING SOLVER.
Back to stable release...
BugFR.sm (6.15 KiB) downloaded 1105 time(s).
#8 Posted: 2016/5/20 17:41:17
1,441 likes in 2,932 posts.
Currently the solution indicated by Andrey applied without other changes makes the function not working even when used in the left side (makes the example file provided by ndtma not working at all); however seems the right way, I'm working on a solution based on this approach.
#9 Posted: 2016/5/26 19:54:14
So, new build is here: http://en.smath.info/forum/yaf_postsm34488_SMath-Studio-0-98-5990--26-May-2016.aspx#post34488
It has corrections related to this topic.
I suggest to update plug-ins according to this comment: http://en.smath.info/forum/yaf_postsm33336_SMath-Studio-0-98-5973--09-May-2016.aspx#post33336
I you have to use not updated plug-in please give a chance to eval() function:
Why these changes are done:
Regards.
Davide Carpi 2016/5/26 20:05:00
#10 Posted: 2016/5/26 20:06:17
Thank you Andrey
I'm reworking the core of this plugin, will be back ASAP.
#11 Posted: 2016/5/26 23:20:58
Alexander O. Melnik
Alexander O. Melnik
This still does not work:
I am a little needy here, because without a working FindRoot() function I am left without a solver that I can use to assign values to variables. I do this all the time in tasks similar to... How many stirrups do I need in this RC beam?
Hope you guys can get me the FIndRoot() back :-)
... A peculiar occurrence. If you place the cursor inside the first red box and hit Ctrl + >, the 2nd red box will evaluate correctly. Magic!!???
#12 Posted: 2016/6/2 14:19:47
Finally fixed.
Please check the latest nightly build (Note: it is required to download of the latest Nonlinear Solvers plug-in).
Davide Carpi 2016/6/2 15:32:00, Alexander O. Melnik 2016/6/2 16:20:00
#13 Posted: 2016/6/2 15:27:00
Alexander O. Melnik
Alexander O. Melnik
Can someone please check this file?
It still does not work with 0.98.5997 and updated non-linear solvers on my machine
Thanks!
#14 Posted: 2016/6/2 15:35:00
Thank you Andrey
Thanks!
It works as it should. You assign A.v in the first solution, thus in the second (C:...) there's nothing to solve. Use Clear(A.v) after the first to make it working the 2nd.
Alexander O. Melnik 2016/6/2 16:21:00
#15 Posted: 2016/6/2 16:19:55
Alexander O. Melnik
Alexander O. Melnik
Thank you Andrey
Thanks!
Thank you, I was not aware that FindRoot() automatically asssigns the result to a variable. I guess I was just stirring mud here..
Actually if this is correct this feature might be undesirable. What if you wooul like to solve a list of equations that have same variable? You will have to use "clear" every time...
Thank you Andrey!!!
#16 Posted: 2016/6/2 16:49:28
I know, and there are several other drawbacks related to this feature; as mentioned in the BTS some days ago about one of these drawbacks, in the next plugin version this feature will be removed. Boolean equal in initial guess will means "use these values as initial guess for that unknown".
Alexander O. Melnik 2016/6/2 16:55:00
#17 Posted: 2016/6/3 02:55:30
with Smath 5346 UNofficial release. No idea if it makes sense ?
#18 Posted: 2016/6/5 19:19:30
I cannot reproduce neither with version 1.0999.5 of the plugin nor with later versions (strange). I suppose it may have sense, in some way, since undefined variables are store as names. However the second result is wrong, so something definitely goes wrong in that case :/
