HIRES Chokes Smath Rkadapt
HIRES Chokes Smath Rkadapt - HIRES Chokes Smath Rkadapt - 消息
#1 已发布: 2016/10/9 02:37:18
983个赞,共6,866个帖子。
The max span is 0..10 Else attempt gives either two types of error.
The setup is correct but the result is a bit short of production.
Designers: that is just a report for your bed time thinking.
Cheers, Jean
ODE Rkadapt HIRES.sm (562.62 KiB)已下载 1399 次。
#2 已发布: 2016/10/9 04:04:00
325个赞和1个踩,共2,052个帖子。
Hello Jean,
Why don't you use stiff solvers, for example from DotNumerics plugin. They will cope with this equations well (dn_AdamsMoulton, dn_ExplicitRK45, dn_GearsBDF..).
P.S. By the way, uni made many ode solvers in few plugins, and I think SMath is very good regarding ODE solvers
#3 已发布: 2016/10/9 10:45:08
983个赞,共6,866个帖子。
Thanks Radovan,
Here is well done, Jean
ODE HIRES.sm (41.06 KiB)已下载 1362 次。
